One vertical green line on my AQUOS LC-70LE740E TV
  • ivtec
    • Dec 2008
    • 1967
    Re: One vertical green line on my AQUOS LC-70LE740E TV
    Originally posted by hoot
    Okay, I will focus on the COF closest to the green line and the one next to it.
    If you have the green line in the meddle or close you have nothing to loose, if it was my Tv had it in the meddle that would bother me and i would have nothing to loose i would try Davi.p instructions if i couldn't get rid of it i would trash tv anyway. Some people don't mind the line, i do,i hate it if they are very noticeable , it's a state of mind thing
    • hoot
      • Nov 2021
      • 28
      • Global
      I will apply heat (270-370°c) for 1-2s on the "1st" COF. If it does not work I will move on to the "2nd".
      On each I will start in the middle and move outwards.
      • CityZen
        • May 2014
        • 40
        I'm not an experienced TV fixer, but based on my understanding of LCDs, the problem could be in a couple different places: the connection of the driver chip to the flex cable, or the connection of the flex cable to the actual LCD. If probing around the chip yields nothing, consider gentle probing where the flex meets the screen.
        • hoot
          • Nov 2021
          • 28
          • Global
          That I will keep in mind. Do you suggest going with the soldering iron where the flex meets the screen?
          • CityZen
            • May 2014
            • 40
            I don't know, but I wouldn't do it myself. Just try probing with a wooden or plastic probe first to see if there's any effect.
            • hoot
              • Nov 2021
              • 28
              • Global
              #26
              Got ya! First I'm preparing for the heating operation. If the TV survives without the issue being resolved, I will do that. Actually I could apply pressure to these points before I do that.
              • CityZen
                • May 2014
                • 40
                I just had a thought about an experiment that might help us both.
                LCD screens have drivers for the horizontal lines (rows) and for the vertical lines (columns). Normally, the drivers for the horizontal lines are on the sides of the screen, and are attached similarly to how you see the tabs on the bottom of your screen.
                However, on recent LCD screens, I've only seen tabs on the bottom. I've had a theory that the drivers for the sides are also fed through the tabs on the bottom of the screen. If this is the case, then the next question is which tabs feed the rows, and which ones feed the columns? I suppose it's possible that a tab could feed both rows and columns, as well.
                In any case, the experiment is simple: run the TV with one of the outermost tab boards disconnected. (Unplug the U-shaped flex cable that joins two tabs.) Then observe the effect on the image. (There's a small possibility that running the TV like this could result in bad things, but I think it's not very likely. You must decide if you're willing to take this risk.)
                I'm currently trying to resolve an issue on a TV of my own, though right now it's in a different place than I am, or I'd try this experiment myself.
                How might this experiment benefit you? Well, if it is the case that the outermost tab is responsible for the horizontal lines, then it must be the case that the tabs that feed the vertical lines are just the ones from the center boards, and therefore the ones you need to check are different than the ones you marked. (You marked the 3rd & 4th tabs from the left; you might need to check the 5th or 6th.)
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #28
                  Citizen the experiment you are suggesting is totally unuseful, 4 your information rows are driven by chips within the glass.
                  • hoot
                    • Nov 2021
                    • 28
                    • Global
                    #29
                    According to what I have researched the POC ribbon can take 230°c long time exposure and 400°c short time exposure. So the heat will most likey be an issue for the surrounding components before it damages the ribbon itself. I will get some ribbons from an old and broken monitor so I can practice a bit.
                    • CityZen
                      • May 2014
                      • 40
                      I can understand that, but one thing is still needed: how does the data get to the drivers within the glass? The only connections are at the bottom of the screen.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4539
                        • Italy - Milan
                        #31
                        the question you make is not relevant, the defect is on a column connection of source driver, gate drivers deesn't matters here..
                        • hoot
                          • Nov 2021
                          • 28
                          • Global
                          #32
                          Ready for practice!
                          • CityZen
                            • May 2014
                            • 40
                            The question I asked is certainly relevant to me.
                            The relevance to the original poster is as I stated: it could affect which tab corresponds to the line in question.
                            • CityZen
                              • May 2014
                              • 40
                              Okay, so I got back to my own TV and tried the experiment I mentioned earlier (leaving one bottom board disconnected). Unfortunately, the result was not as interesting as I hoped: the whole screen fails to show any image.
                              I did try various experiments masking out some of the connections, and they did make certain vertical bands of the screen display improperly.
                              After thinking about the way LCD screens are driven, I realized that the horizontal rows are only driven by timing signals, whereas the vertical columns are driven by pixel data. Only two signals are needed for the rows: reset and count.
                              For this thread, the only conclusion is that the tabs hoot indicated are probably the ones he needs to check.
                              • hoot
                                • Nov 2021
                                • 28
                                • Global
                                #35
                                That's good to hear. I was just guessing.
                                • hoot
                                  • Nov 2021
                                  • 28
                                  • Global
                                  #36
                                  Since I wasnt able to find my modern soldering station I have used this old timey heavy duty one:
                                  Here I have three ribbons. The one at the bottom I have played around with quite a bit to get the feel for it. The middle I have applied 1-2s light touch in the middle as well as 2 points to the left and 2 points to the right. The top one is untouched. The deformation of the flex is due to me taping them onto epoxy:
                                  Here I did apply 20s in the middle:
                                  Here another 20s on the some COF:
                                  Superficially they seem to be quite resilient. When I'll do this on the TV I will stick to 1-2s and a light touch. I will have a metronome running at 240bpm to ensure the timing is right.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    #37
                                    how many watts that iron?
                                    • hoot
                                      • Nov 2021
                                      • 28
                                      • Global
                                      #38
                                      Thats all it says. Judging by what your saying the iron did not get hot enough?
                                      • hoot
                                        • Nov 2021
                                        • 28
                                        • Global
                                        #39
                                        I now have tried with this one (no station directly into the powersocket) for 20s in the middel (5min heatup time):
                                        • hoot
                                          • Nov 2021
                                          • 28
                                          • Global
                                          #40
                                          Started with 230°C 1-2s on different points of the COF on the left and right flex next to the green line, went to 260°C, to 300°C, eventually to 370°C. The TV survived just fine the line however remained.
                                          By playing around with the connection seen below, I can get a hole in the line. Disconnecting completly will turn the whole section white. Dont know if that is a useful clue. If there is nothing more to be done I will get rid of the TV.
                                          • cubytus
                                            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                            by cubytus
                                            Hi to all,
                                            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                            01-10-2024, 01:26 AM
                                          • otaku_nut
                                            Vizio E701i-A3 fixed but now has red vertical line
                                            by otaku_nut
                                            Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                            08-19-2025, 06:11 PM
                                          • TrueSword88
                                            Kogan - KALED65XU9220STB - Blue Vertical Line
                                            by TrueSword88
                                            Hi all.
                                            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                            The line just happens to coincide with the end of COF and start of the next COF (attached).
                                            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                            Hoping to fix...
                                            05-05-2023, 04:28 PM
                                          • almarhum
                                            To fix laptop screen vertical line by working on its EDP cable
                                            by almarhum
                                            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                                            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                                            05-07-2024, 02:12 PM
                                          • mrsith
                                            Samsung UE58TU7100K - no picture, vertical line
                                            by mrsith
                                            Hi.
                                            Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                                            This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                                            Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                                            02-07-2023, 11:18 AM
