One vertical green line on my AQUOS LC-70LE740E TV
  • hoot
    • Nov 2021
    • 28
    • Global
    on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
    Does anyone know what the issue could be?
    Up close it looks something like this.
    Can this fault be serviced?
    What I want to do is the following:
    gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line. Pushing a driver IC onto the flex cable it sits on to restore the lost connection. When the problematic area is found installing something that pushes it permanently.
    Thanks in advance
  • hoot
    • Nov 2021
    • 28
    • Global
    Re: One vertical green line on my AQUOS LC-70LE740E TV
    When I loose the contact on the connection and apply different amounts of pressure I get this kind of artifacting (some of it looks just like the original vertical line. The original vertical line however does not go away when reconnecting):
    • hoot
      • Nov 2021
      • 28
      • Global
      To be clear...
      This is the connector fully engaged:
      This is the connector fully loosened
      This is one of the many artifacts that apear, when the loosened connector is lightly pressed down (notice the permanent line is brighter):
      This is another one of the many artifacts that apear, when the loosened connector is lightly pressed down:
      These artefacts are lines or plains that are white, blue, red or green. Next to that connector is another one that behaves the same as far as I can tell.
      Another idea would be to replace one of the PCBs:
      There is another one on the right of them but its covered by a metal plate. The whole housing is of metal, beautiful construction.
      Maybe unplugging the cables on the pcbs and cleaning them would do the job? I have no clue about this stuff, but im feeling like dumpimg this high quality made in japan TV is a waste. Defenitly no warrenty on this one. Pressing the ribbon under the connector doesnt effect the screen at all.
      • ivtec
        • Dec 2008
        • 1967
        There is nothing you can do, this is a display fault, I have a Philips 46 with same line but my luck is right in the left side close to the side and only notice if i watch a movie and i fixate my eyes on it, since i use this tv most times for soccer and field is green, not bothering me at all,
        • Davi.p
          Hobbist
          • Sep 2009
          • 4264
          • Italy - Milan
          you can only try to slightly reflow the near COF using stylus soldering iron, some precautions must be taken..
          • hoot
            • Nov 2021
            • 28
            • Global
            Sorry, I'm not a native english speaker. What does COF stand for?
            @ivtec I see. Maybe I could get into golf... If per chance Im able to come up with a solution Ill let you know, so you can enjoy your soccerball games in full glory!
            • Davi.p
              Hobbist
              • Sep 2009
              • 4264
              • Italy - Milan
              COF are the chips soldered on to the tab, therefore the tiny flat cables glued to the screen, if you watch them normally the chips are in the opposite side of tab, so you must carefully heaten the top side under the chip pins, but first: remove/flip the panel's board and put a shim under the right cof so you can make pressure without benting / breaking it, not use plastics or metal, must use some heat resistant and possibly not much heavy. Then remount the pcb, now with a tip scroll under the chip pressing it until you find the point that restores the correct image, so you can heaten with sodering iron, do it gently with increasing duration / pressure.. until the line goes away and stay there. Be very sensitive because the chip is like glass and breaks very easily..
              • hoot
                • Nov 2021
                • 28
                • Global
                I see! Thank you for that detailed describtion. This seems to require a substancial amount of skill. I will think about it, but I am not sure if I am skilled enough to do this. Shouldnt have the pressure I applied on there have had an impact on the green line on the screen?
                Is it possible that a PCB swap could do the trick?
                • Davi.p
                  Hobbist
                  • Sep 2009
                  • 4264
                  • Italy - Milan
                  You don't understand me, the fault is in cof chip soldering, don't stupidly waste money in boards that would be helpful for another user, i'm about 13year behind lcd repairs, i know what i say.. if the heating doesn't improve, the fault is in cof line output circuitry..
                  • hoot
                    • Nov 2021
                    • 28
                    • Global
                    That is good to know, thank you. I'm lucky to benifit from your experience. So I will need to fix the soldering of the COF chip. I'm worried about going near that area with a soldering Iron, but since you have so much experience I will approach this subject.
                    I will read your description very carfully and will write more soon.
                    I will respond tomorrow. Thank you very much.
                    • Davi.p
                      Hobbist
                      • Sep 2009
                      • 4264
                      • Italy - Milan
                      feel free to ask if you have doubts, those films are high temperature resistant plastic films, so you can insist some seconds with the iron on.. to locate the faulty soldering point before using the iron, use a toothpick. If you manage to cancel the line, before closing all up add a soft shim in front of the cof chip to be able to keep it slightly pressed to the frame.
                      • CityZen
                        • May 2014
                        • 40
                        For reference, here is a set of COF (chip-on-flex) on the tabs of a Samsung TV. Note the long and thin driver IC's. "Tab" refers to tape-automated bonding, and it's the method used to attach the chip to the flex tape, though the name is also applied to the whole COF/tape assembly as well.
                        • hoot
                          • Nov 2021
                          • 28
                          • Global
                          Thank you very much, this is critical information.
                          So Im going to loosen the PCB put epoxy under the COF and put the pcb back to its place.
                          Then Im going to apply pressure with a toothpick on differrent spots on the area shown below.
                          After I have located the critical spot Im going to take a soldering iron and apply heat until the line disapears. What temperature do I set my soldering iron at?
                          • Davi.p
                            Hobbist
                            • Sep 2009
                            • 4264
                            • Italy - Milan
                            Ok it's all correct except for epoxy that i don't know its property but i don't have a good material to suggest, i think is ok, for the temperature keep it low like a 20w iron, sorry i've never had a soldering station... empty pockets here..
                            • hoot
                              • Nov 2021
                              • 28
                              • Global
                              Very well. Im going to try to locate the spot by appling pressure. Then Im going to apply something between 270 and 370°c for around 0.5-2 seconds on that located spot. Wish me luck.
                              • hoot
                                • Nov 2021
                                • 28
                                • Global
                                Appling pressure to the COF next to the green line did not work.
                                • Davi.p
                                  Hobbist
                                  • Sep 2009
                                  • 4264
                                  • Italy - Milan
                                  Sorry, so decide whether to apply heat or not and keep the screen faulty.
                                  Are u sure is the right tab or is the next one?
                                  • hoot
                                    • Nov 2021
                                    • 28
                                    • Global
                                    Might be the next one. I will double check on both. If it is still worth a shot appling heat although pressure did not show any change I think I'll do it anyway.
                                    • Davi.p
                                      Hobbist
                                      • Sep 2009
                                      • 4264
                                      • Italy - Milan
                                      COF contacts are in the perimeter, but not all the lines to the screen start from the side that face to the screen
                                      • hoot
                                        • Nov 2021
                                        • 28
                                        • Global
                                        Okay, I will focus on the COF closest to the green line and the one next to it.
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
                                        • almarhum
                                          To fix laptop screen vertical line by working on its EDP cable
                                          by almarhum
                                          Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                                          As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                                          05-07-2024, 02:12 PM
                                        • mrsith
                                          Samsung UE58TU7100K - no picture, vertical line
                                          by mrsith
                                          Hi.
                                          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                                          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                                          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                                          02-07-2023, 11:18 AM
                                        • bdalkiran
                                          55EC930V white vertical line appeared (need help)
                                          by bdalkiran
                                          Dear All,
                                          I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
                                          Please advice how to proceed and what is the...
                                          01-13-2023, 04:16 PM
