LG 55EC930V/55EC9300 repair assistance
  • Arkious
    • Nov 2021
    • United Kingdom
    I’ve followed all the info I can find on the site and I’m hoping if you guys could tell me which you think is broken.
    So to start, when the power button is pressed the relay engages and the red optical light illuminates for about 3 seconds before the relay disengages. It does this all the time no matters how many times you try or after leaving it unplugged for prolonged periods. The LG logo stays permanently lit with no fading when the power is connected
    So I followed the power supply and t-con test procedure and the power supply gives out the correct voltages at all times with the jumpers installed.
    If I connect the panel to the t-con and power up (with the main board disconnected the whole time), the screen lights up with a few horizontal lines across it after 10 or so seconds. Over the course of the next 10-20 seconds the whole panel gets the horizontal lines and then they begin to flicker, at which point the t-con begins to click and I disconnect the power. I’ve carried out no further testing.
    Does this point to a bad t-con or bad pannel?
    Thanks very much for taking the time to read
  • TeslaMichael
    • Oct 2020
    • 102
    Re: LG 55EC930V/55EC9300 repair assistance
    Can you upload images of the TV inside and one image of the problem ? I think it could be the t-con, but also the panel, if it starts to flicker very fast.
    • dskall
      • Oct 2016
      • 2905
      • usa
      So you mean the LG logo on tv not on the screen? And you've disconnected t-con cables one at a time and what did you get?
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
      • alltvrepairs
        Lg TCon test pins for screen test
        by alltvrepairs
        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
        Appreciate your help....
        06-13-2025, 06:33 AM
