Un50mu6070 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 625
    Re: Un50mu6070 Mainboard issue
    I just got a cheap ch341a to start with.
    I’ll dump the chip again tomorrow and upload again.
    Thanks for the help
    Appreciate it
    • lotas
      • Jan 2016
      • 4803
      • Russia
      And what soft do you have for the programmer?
      Here is the latest version of "Colibri" for the CH341A.
      • Storyteller12
        • Jun 2020
        • 625
        I’m using AsProgrammer. I’ll try colibri and see if that makes a difference
        • lotas
          • Jan 2016
          • 4803
          • Russia
          Driver ch341
          • lotas
            • Jan 2016
            • 4803
            • Russia
            Today I checked with "Colibri", it does not save "STATUS REGISTERS", let's stop at AsProgrammer_2.1.0.13 everything is fine with it.
            • Storyteller12
              • Jun 2020
              • 625
              Ok. Tried again using your version of colibri, and asprogrammer. Still not working.
              Everything says successful but nothing
              I tried dumping my eeprom that does work and writing that but nothing.
              Thinking it may be the chip itself is just bad and not reusable.
              • lotas
                • Jan 2016
                • 4803
                • Russia
                #27
                I will now write the correct order of actions in AsProgrammer.
                It doesn't work on Colibri.
                • Storyteller12
                  • Jun 2020
                  • 625
                  Thanks lotas. You been more than helpful.
                  I appreciate you
                  • lotas
                    • Jan 2016
                    • 4803
                    • Russia
                    #29
                    In the program:
                    1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                    2. Click "Unprotect".
                    3. Click "Erase IC" and "Yes".
                    4. Click "Open File" and select your corrected Dump.
                    5. Press "Program IC" and "Yes".
                    6. Click "Verify IC".
                    7. Press the down arrow to the right of "Unprotect" and select "Edition SREG", put a check mark on S7, S3, S14, S9 and press "Write" and "Yes"
                    7. Close the program. Ready.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4516
                      • Italy - Milan
                      #30
                      Reading back i don't know why i have written my first post, you don't even have described the tv symptoms...
                      • Storyteller12
                        • Jun 2020
                        • 625
                        Thanks Lotas, but still won't work.
                        I did exactly as you wrote.
                        I also tried another chip I found on another mainboard I had laying around and same results.
                        I made sure the registers were 0x88 and 0x42.
                        I must be doing something wrong.
                        • Storyteller12
                          • Jun 2020
                          • 625
                          Davi.P:
                          You were right though.it’s definitely that eeprom that’s bad. All I did was swap eeprom from a 55” mainboard I had and it works.
                          I’m just trying to figure out why the eeprom I’m programming will not work. it’s definitely the eeprom.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4516
                            • Italy - Milan
                            #33
                            The only possible answers i find is that that chip has some hidden / secret command made for Samsung to make programmed obsolescence, i mean a command to read/write a secret register where it is wrote: "this tv is young / this tv is old and needs to die in a reciclery". Try to find its datasheet, if i'm right you'll not find it..
                            • lotas
                              • Jan 2016
                              • 4803
                              • Russia
                              #34
                              Try this dump
                              • lotas
                                • Jan 2016
                                • 4803
                                • Russia
                                #35
                                When dismantling and installing the 25Q40, were they not damaged, did the adjacent components move?
                                • Storyteller12
                                  • Jun 2020
                                  • 625
                                  I thought that also. So I switched back the eeprom I took from the 55” tv it still works fine.
                                  Also I tried to dump the working eeprom I have and write it but It's still not working. Getting frustrated with it
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4516
                                    • Italy - Milan
                                    #37
                                    you would need a logic analyzer like cheap Saleae and the right software to back engineering what the tv asks to the memory...
                                    • lotas
                                      • Jan 2016
                                      • 4803
                                      • Russia
                                      #38
                                      Storyteller12 What is your CH341A programmer, there are several types of them (black, green ...) post a photo of it.
                                      • Storyteller12
                                        • Jun 2020
                                        • 625
                                        Im using this programmer
                                        • lotas
                                          • Jan 2016
                                          • 4803
                                          • Russia
                                          #40
                                          Refinement of the programmer
                                          In the process of working with the programmer, some shortcomings were revealed,
                                          one of them: it is not possible to clear / set the QE bit in the second status register.
                                          We read the datasheet, for example, on the W25Q64FV chip, and find the Quad Enable (QE) punt,
                                          which has a warning:
                                          WARNING: If the / WP or / HOLD pins are tied directly to the power supply or ground during
                                          standard SPI or Dual SPI operation, the QE bit should never be set to a 1.
                                          To fix this flaw, you need to disconnect the legs #WP (pin 3) and #HOLD (pin7) from VCC
                                          and connect them to VCC through 4.7 kΩ resistors.
                                          I propose a step-by-step instruction for finalizing the "black programmer":
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Stephen
                                            A2991 Logic Board issue, 20volts 0 amps help!
                                            by Stephen
                                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                            09-10-2025, 03:16 PM
                                          • Stephen
                                            A2991 logic board issue, 20volts 0 amps help!
                                            by Stephen
                                            09-10-2025, 03:15 PM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
