Panasonic TCP50GT25 problem
  • Fripacks
    • Jun 2021
    • 59
    I have this plasma to repair, the problem, I can turn on but nothing no sound no picture. The red light in front have no blinking and stay red, I see on the Y Board a green light no blinking too and stay green, I think it's Main Board or Power Supply boards is culprit, how I have to troubleshooting this?
  • Fripacks
    • Jun 2021
    • 59
    Re: Panasonic TCP50GT25 problem
    Someone can help?
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Is there a green light on the SS board as well?
      • Fripacks
        • Jun 2021
        • 59
        Yes , it's green light on the SS board too
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Does the screen light up at all ? Turn off the lights in the room and check.
          • Fripacks
            • Jun 2021
            • 59
            Thanks, yes the screen light up , I see in dark room, maybe the Main Board defect?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Yes, that's it.
              • jimjoe123
                LCD TV Green/Pink screen problem
                by jimjoe123
                I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                Then each time...
                02-23-2020, 01:29 AM
              • AquaMan Ua
                Problem with PANASONIC CF53 laptop after changing BIOS settings
                by AquaMan Ua
                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                05-17-2025, 09:40 AM
              • shahnld
                Sony kdl 65xg9505 green amber blinking
                by shahnld
                Good Day.
                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                01-03-2024, 03:05 PM
              • hugocarmo
                Panasonic TX-24A1UN CRT Sound and Input problem.
                by hugocarmo
                Hi.
                IΒ΄ve been given an old CRT from Panasonic, itΒ΄s almost new, it was storaged and almost not used since bought.
                It is imaculate inside, almost no dust or debris inside.
                The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                So I started to look for a service manual, I found one, and started from the beginning.
                Most of the times the caps are the problem so I orderer all the caps for all boards,...
                04-26-2025, 07:45 PM
              • renech
                panasonic TH-42PC77U plasma television half screen problem
                by renech
                hello,
                I hope someone on this forum can assist me.
                I have a panasonic TH-42PC77U plasma television.
                the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                I have read some posts that suggest the problem is related to the boards on the left...
                12-12-2022, 06:53 PM
