LTV32 w1 westinghouse tv
Re: LTV32 w1 westinghouse tv
So I have recapped the board and nothing has changed. when I plug it in the blue light flashes and turns on, then in a few seconds it goes to orange. the power button, when pressed causes the same result.Comment
I just tried hooking it up to an Xbox and still no luck. It takes ~ 9 seconds for the LED to go from blue to orange (standby). Any more ideas?Comment
Here's a couple of ideas for eliminating 'no signal' as a possible problem.Originally posted by acidophilusI don't have cable so that makes it more difficult.
Hook up an antenna -any kind of an antenna. My favorite is a 4' length of very old telephone wire. It plugs right into the coax connector. Try hitting the 'Input' button to see if the sound changes.
Another source I use is an old Nintendo with composite outputs. Hook it up, then hit the 'Input' button to see if you can at least hear the background music as you switch between inputs.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Ok, I have tried several inputs (VGA, HD, AV1) and tried to flip through them all while the blue LED is on. I also played with the volume. Nothing.Originally posted by PlainBillHere's a couple of ideas for eliminating 'no signal' as a possible problem.
PlainBill
The backlights don't flicker or anything, just the "on" LED.Comment
"Nobody has had any problems with a westinghouse 32 inch LCD TV? or any idea of any common problems?"
i also have one of these little 'pains' sitting here - given to me by a friend who dumped his westinghouse tv. i removed the supply to do a quick inspection but haven't had the time to go any further on it. i didn't even bother testing it in the tv yet - just pulled the supply right out.. it's seems it's always the same failure mode... for a few months, the tv 'plays' for a number of minutes, then blue light, then off. only a power cycle allows it to come back to life. after that period of time is over you get what you have now.. just no-op.
i think there are 1000s of dead or semi-dead units of this power supply out there in 27" & 32" westinghouse lcds, vizio, and a few others. they died very prematurely on a lot of people. there was talk about class action - never happened of course... people with big talk - no time for action. delta elec always made a great product so it seems that something caught them off guard on this supply. the mechanical assembly / design of this board appears to be top notch - the caps always look solid and the rest of the parts look well heat-sunk.. there's something else going on.. i did see one guy - and only one on the whole web - who posted a note concerning this supply saying that there was a 47uF cap somewhere that had to be replaced.. i haven't had the time to investigate it yet but i'll be watching this thread & hopefully you'll make some headway.. (-:Comment
Have you measured the actual output voltages of the power supply? I've been operating under the assumption that the flaw was probably in the signal board, and likely unrepairable. This wouldn't be the first time my assumptions turned out to be wrong.
Success! I found the T1 pin on the transformer had a bad connection so I re-soldered it and it turned on. Spread the word.Comment
hi,
i used your photo to mark out the T1 leads in yellow (from what I can see). mine appear to be good. BUT, the one I circled in red (one side of capacitor C310) is definitely bad (cold) and this would explain exactly the type of behavior that many have seen after a 20 minute warm-up /heat-up cycle.
was yours one of the joints circled in yellow? either way, that was a great find. if this is typical, and it just might be, then the thing that caught Delta "off-guard" was the crappy wave-soldering baths that were done on these boards. this would also fit right in with the typical observation that "everything looks good" .. no bloated caps, etc. in fact, the top of these boards always seem to look 'good' .. it's the bottom soldering job that has problems - a little time & temperature and suddenly bam .. trouble after 14 months. but it would be even more interesting if it turns out to be the same problem joint across many of the boards. moral of the story.. don't go looking too deep.. it could be staring you right in the face the whole time..
~Attached Filesif you find these attachements useful please consider making a small donation to the site
I resoldered the joint on the upper left. the unit works well now. and as you said about looking too deep, I should have looked first off, I ended up replacing all of the caps when all I really needed was about an inch of solder.Comment
yeah, that's pin 5 ... mine looks fine but this all brings up a great point. these transformers are big & heavy and under heat & stress they will expand and attempt to pull their leads up from the pcb a bit. if the solder job is crappy then you're gonna run into this sort of thing. i think you just saved a bunch of people some work in the future. thanks for coming back & posting your find.
~Comment
I am actually probably going to redo all of the joints, just to be safe. I hope others are able to fix this bored without too much work. Thanks for the input from everyone else.Comment
Thanks to all for your previous posts. I am having trouble with my sound "blipping" off at approximate 20 to 30 minute intervals and lately, the sound/picture going out completely. Unplugging and replugging the power cord would reset it. I, too, took a hard look at the Delta board and found a cold (cracked) solder joint at C310 [photo attached] as referenced by 12ax7a on 4/20; everything else looked tight. Just finished the resolder and will test tonight.
In the meantime, I've had another minor problem ever since the unit was new - the blue power-on indicator light on the front has never worked despite having it looked at by a Best Buy service maintainer (a whole 'nother story there) and calls to WX to no avail. I know that it has the ABILITY to work since it flashes on whenever the set is either unplugged or plugged in to wall power. The remote sensor on the same board works just fine. I've taken a photo of the board [attached] and even though everything SEEMS to be OK, the silk screened area under the capacitor shows two mounting possibilities; I'm wondering if a different capacitor of whatever size would "enable" the light. I want it to work because without it, we sometimes need to push our power on button on the remote several times before we see backlight and the input source graphics.
Any ideas???
Thanks in advance.............Dave H.Attached Filesif you find these attachements useful please consider making a small donation to the site
by zlr8rHey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
To begin with, this laptop was dead-dead.
Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;- am getting white power led
- 5-long-flashes on CAPS Lock and NUM lock
- then, fan full speed
- CPU heats up some (smaller die PCH, does not)
- always constant black screen no matter what's tried
- no USB recognition
- no HDMI output
I tried... -
by odtechGreetings friends.
I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
Any guidance... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by bcstedtLG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
Problem:
On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)... -
by cmlewis89Hi folks,
I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...12 Photos - Loading...
