Please help me fix my beloved Panasonic TC-P65ST30
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4459
    • Italy - Milan
    #41
    Re: Please help me fix my beloved Panasonic TC-P65ST30
    to test the drain pin you can solder to the solder side a long wire or you can simply trace where the drain pin is connected to an exposed pin of someone else component, usually the transformer pin, or better a diode bridge pin (check continuity beteween mosfet and it first)
    • Ren01
      • Aug 2021
      • 33
      Thank you for that tip! Using one probe on on the leg of d412 which is shorted with the drain and another probe on the heat sink I’m getting 0 volts DC or AC. Similarly, the source is also 0 volts.
      Would this mean the issue is the mosfet isn’t being fed VCC?
      • Ren01
        • Aug 2021
        • 33
        I traced VCC back to these components, do they look bad? In circuit d407 is measuring very high resistance both ways. D404 measures around 200 ohms one way and very high the other. I also can’t read the labels at all.
        • Ren01
          • Aug 2021
          • 33
          Just a side note, VCC is at 0 volts, and I have confirmed there is 120 volts going to the main power board.
          It seems the transformer connected to VCC is also putting out 0 volts :/
          • Ren01
            • Aug 2021
            • 33
            The transformer is also not receiving any voltage on the other side, and that seems to be connected to a relay on another board that I cannot tell if it is faulty. This is going over my head.
            • Ren01
              • Aug 2021
              • 33
              VCC is seeing 143 ohms between it and source pin, but only in one direction so I'm guessing diode.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4459
                • Italy - Milan
                #47
                test in volt the diodes D201A / D202A under heatsink, both pins.. them are on the primary side
                • Ren01
                  • Aug 2021
                  • 33
                  Plot twist, I ordered a replacement board from TV Parts today and the TV still won’t turn on! New board is exhibiting same issues and I’m stumped!
                  • budwich
                    • Jul 2015
                    • 3097
                    this thread might help you a bit... https://www.badcaps.net/forum/showth...t=panasonic+sm
                    There is a tech guide therein which might give you some help.
                    IF the replacement board is good (was good) and there was no changed, that would suggest that you are looking in the wrong place for the root cause.
                    Based on a quick peek at the guide, it appears that some form of standby voltage should exist. That is fed to the control board which then can do "stuff" to cause tv functions thereafter.
                    Actually, one question is: which board did you replace?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4459
                      • Italy - Milan
                      #50
                      The same old boring board swap... sadly it is hard to improve knowledge by forum use...
                      Unless you don't buy the entire power boards kit it is nonsense..
                      • Ren01
                        • Aug 2021
                        • 33
                        Just a PSA, that I did end up fixing my TV, but DO NOT BUY parts from TV Parts Today or www.tvpartstoday.com . They sold me a defective PSU board and it took me an extra month of troubleshooting and buying additional parts to figure this out. Pay more and buy from a competitor that actually tests their boards before sending them out.
                        Thanks again Davi.p for all the help!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4459
                          • Italy - Milan
                          #52
                          bye..
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
                          • Mnawar27
                            Panasonic CF-H2AU24EF3 bios locked
                            by Mnawar27
                            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                            I need help to remove it,
                            thankyou all.
                            SN; 2FKCA26876...
                            11-16-2024, 08:00 AM
