Samsung un50eh5000fxza - no power, no red light.
  • marquisexb
    • Aug 2021
    • 7
    So I have a Samsung un50eh5000fxza, that all of a sudden stopped powering on. The TV worked great for years until then.
    I tried replacing the power board (BN44-00499A) and then the main board (BN94-05750k), but still no power.
    I'm getting the T-Conn board next & am going to replace that. Anything else I should attempt? Anything else I should look at?
    Pictures included of the old & replaced part (T-Conn hasn't been changed yet.)
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung un50eh5000fxza - no power, no red light.
    If you unplug the mainboard from the power supply and power up do the backlights come on.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Try dick_barton's suggestion first. If you don't get backlights:
      1) Unplug the TV and wait 30min. for all capacitors to discharge.
      2) Plug all items back in to their boards EXCEPT the backlight connector upon the power supply, leave it detached.
      3) While observing the stand-by light, plug the TV in to the wall and answer this question:
      Did the stand-by light turn on or flash momentarily? If it turned on then press the power button and look to see if the stand-by light starts flashing. If it does, or if it flashed momentarily upon plug in do the flashlight test upon the screen to see if a picture is present. If an image is present upon the screen the backlights are severely short.
      When you plug this model in to the wall the Power Supply sends a pulse of current to the backlights to check their condition. If they are severely short there's a safety on the Power Supply that will prevent the Power Supply from powering up. In this condition there will be the appearance of no power and no stand-by light. This could lead to misdiagnosing the Power Supply is defective.
      Taking the severely short backlights out of the equation by detaching their connector from the Power Supply will not trip the safety and allow the TV to power up without backlights. If the screen is good an image should be present and should be visible with a bright flashlight shone upon the screen.
      Also, check the lower right and left corner of the screen to see if it is chipped or cracked behind the bezel. The 50" EH, H and J model Samsung's are notorious for having too small of screen supports on the corners, often leading to a cracked screen you can't see until the bezel is removed. This won't keep the TV from powering up but should be checked before buying parts.
      Hope this helps.
      They call me......."threadkiller"
      • marquisexb
        • Aug 2021
        • 7
        YES!
        It seems the next suggestion is if the backlights don't come on. Now that they've come on, what should I try next?
        • CapLeaker
          Leaking Member
          • 8215
          A new main board
          • marquisexb
            • Aug 2021
            • 7
            FWIW - I plugged the original power supply to the backlights & tried the same test & that turned on as well. So I'm guessing it didn't need to be replaced.
            Also I recorded a video of what I'm seeing, if this helps:
            https://www.youtube.com/watch?v=gOzOtUYNw60
            • marquisexb
              • Aug 2021
              • 7
              Can I ask a dumb question - does the part # need to be exactly the same? For instance this main board that came with my tv is BN94-05750K. But when I google either that # or the tv model UN50EH5300FXZA, I get multiple numbers:
              * BN97-06298N
              * BN41-01812A
              * BN94-07162W
              * BN94-06692L
              etc.
              Does it matter which one I get, or should I stay with the BN94-05750K?
              • handsworth
                • Oct 2015
                • 174
                one is the part #, the other is the blank board #. Look on the tv label and you'll see the model #of the tv and also a version #, Match one of the previous numbers with the correct version #number.
                • marquisexb
                  • Aug 2021
                  • 7
                  A new main board
                  Thanks. I've ordered a(nother) main board. Will test out & report back.
                  • marquisexb
                    • Aug 2021
                    • 7
                    Ok so ordering a working main board & replacing that worked!
                    It was the only part needed, and the first replacement I got didn't work.
                    • neilc6
                      • Nov 2015
                      • 1550
                      If you want your backlights to last, turn them down to 8-10 and turn off eco sensor. Lots of backlight failures on E model years from running at max.
                      • mcoogan_2001
                        • Jul 2015
                        you can bake the board and it'll start working again
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • ipatch
                          troubleshooting microsoft surface pro 4 no power no led charge light
                          by ipatch
                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                          10-05-2023, 11:59 AM
                        • russpall
                          LG 39ln540v - red light flashes twice, no power to LED driver?
                          by russpall
                          Hi there,
                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                          08-27-2024, 01:07 PM
                        • hill01
                          Samsung UE75MU7009TXZG Endless Power Cycle
                          by hill01
                          Hi everyone and thanks in advance for any help I might get here
                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                          Since a few days, the TV won't turn...
                          11-17-2021, 02:52 PM
                        • JRyan
                          Samsung TV UN60J620DAF blinking power light
                          by JRyan
                          Saved this TV from the trash but it will not power on the red power indicator light blinks 6 times with no display. I've attached pics of the power board(1st pic) and mainboard(2nd pic). I don't see any blown caps on pb like I expected so what do y'all think is the issue?...
                          09-03-2023, 07:56 PM
