Philips 42PFL3609S/98 Shuts down after sometime
  • vernond
    • Feb 2013
    • 45
    • Malaysia
    Hi.
    I have a Philips 42PFL3609S/98 TV that shuts down after some time. If the TV is not power overnight and is powered on in the morning then it will last longer sometimes up to 2 hours. After the first shutdown, it will be more difficult to switch it on again. It would be easier to restore power if I remove the AC cord and plug it back again.
    Replacing capacitors C805 and C804 didn't solve the problem but made the running time last slightly longer. The old capacitors were giving me a reading of 920 uf. C840 and C840A are giving out a reading of 72uf and were not replaced. The rest of the capacitors and diodes were checked and found to be within tolerance.
    Could the problem be with a faulty CCFL? I have no idea how to get to them? There is a barely visible dark horizontal line across the screen. Any help would be highly appreciated.
  • tiki66
    • Jul 2016
    • 53
    • Croatia
    Re: Philips 42PFL3609S/98 Shuts down after sometime
    Does it switch off just the LCD, the backlight or the whole tv shuts off?
    • vernond
      • Feb 2013
      • 45
      • Malaysia
      The whole TV shutsdown with the relay K801 de-energizing can be heard. Does anyone know the function of this relay?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4458
        • Italy - Milan
        try disconnect the tcon and let the tv stay on longer than usual possibly, if it happens probably a bad semi shorted mosfet on the tcon.. if it doesn't happen try the psu alone with dummy loads and main stage on by proper ps-on like command.. watch if it stays fully on, if it stays then to be seen are dc dc regulators on main board, if none of them then CPU soldering problem...
        Further, tell me if it is present FRC board, between mainb. and tcon..
        • R_J
          • 9588
          I would suspect the small caps like C803 in the standby circuit, or C802 for the main power supply
          • vernond
            • Feb 2013
            • 45
            • Malaysia
            All these caps were check and found to be ok.
            However, I noticed a bulging cap on the mainboard. Bad eyesight made me miss this cap the first time around. Removed it from the board and found the 470uf / 10V cap is giving me only 100uf. Replaced this cap now waiting to test it tomorrow.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4458
              • Italy - Milan
              Expect no success...
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                The service manual refers to DV10 on page 16 and it looks like the capacitor C124 is one of the filter capacitors on that line. DV10 feeds the supply to quite a few IC's so could well be the issue.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4458
                  • Italy - Milan
                  Today is an old lesson to understand, when caps fails them shows defect at cold... never seen one that does different... please update...
                  • vernond
                    • Feb 2013
                    • 45
                    • Malaysia
                    After replacing the 470uf/10v cap on the mainboard the tv is even more difficult to turn on. This is the symptom of failure, sorry for the background noise, getting the little one to reduce the volume is not easy. https://youtu.be/gRlltDRHOVQ
                    Disconnected the TCON connector from the mainboard and tried to switch on the TV, still unable to on. The symptom is the same as the youtube video.
                    Disconnected the power to the CCFL tubes, The symptom remains the same as the youtube video.
                    After knocking the power board, the tv came to life but didn't even last for 1 minute and the power begin to cycle as per the youtube video. All the time when the power cycles on and off the relay can be heard energizing and de-energizing.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4458
                      • Italy - Milan
                      You don't have followed all my suggestions, if you are not able please bring it to a repair center, in your country repair is still a convenient job..
                      PS: i'm suspecting something wrong in the AC det circuitry wherever it is present, so search for the schematics, of the psu, i'm sure i'll find them, then test every part of that simple circuit, again , if you are able...
                      Get the service manual and check your led blinks error code, if it says i'm right, before test it...
                      • vernond
                        • Feb 2013
                        • 45
                        • Malaysia
                        Davi, I've tried to do what you have suggested like disconnecting the TCON board, the rest of your suggestion is beyond my capability.
                        • vernond
                          • Feb 2013
                          • 45
                          • Malaysia
                          Thank you for your valuable advice. The schematics of the power supply is attached to my first post. Will check the blink error code in the service manual.
                          Found the service manual and attached to this post
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4458
                            • Italy - Milan
                            There is no AC det, you must follow the manual on how to enter SDM mode and see level 2 error blinks in the first part of manual....
                            • vernond
                              • Feb 2013
                              • 45
                              • Malaysia
                              Ok thank you. Will try to do that now.
                              • alro7779
                                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                by alro7779
                                Hello, guys!
                                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                09-14-2025, 12:25 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
                              • huzo
                                HP Omen shuts down when loading OS
                                by huzo
                                The model is 15ec-1061nm
                                Board number is DAG3EDMB8D0​
                                SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                10-29-2024, 12:05 AM
                              • brav1ez
                                ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                                by brav1ez
                                I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                                I’ve tried:
                                - CMOS reset
                                - Removing the SSD/HDD
                                - Reseating RAM (removing each stick individually stops boot completely)
                                - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                                With...
                                09-07-2025, 10:47 AM
                              • double_DD
                                Philips curling iron - is this a common AC cable?
                                by double_DD
                                Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                08-18-2025, 10:04 AM
