Screen reconditioning (slightly off topic)
  • capxrf
    • Jan 2010
    • 28
    I have a 32" LCD that I repaired the power supply on to resell. I didn't notice the deep screen scratches till I had already gotten it home. They were noticeable, so I polished them out carefully with a dremel and polishing compound (they were much too deep to do it by hand, and the polishing did work actually). Now the scratches are gone, but the polished areas are very shiny because I polished off the matte screen finish. The Tv looks perfect from certain angles, but terrible where you can see the reflections off the polished areas (its very distracting and unattractive when the tv is on and in a lighted room). This is just a fun project, so I'm not too worried, but does anyone know a solution for this by chance? Any ideas at all? I can give some attempts and post results.
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Screen reconditioning (slightly off topic)
    Why not polish the whole thing to at least make it uniform?
    • f67bird
      Technician
      • Apr 2007
      • 57
      If you have not buffed thru the polarizer all the way to the glass, I would suggest trying something like 800 grit sandpaper, but not sanding with it...try rolling it on the shiny spot in hopes of roughing the polarizer up somewhat. Sort of like rolling your finger when having your fingerprints taken.
      Just something to think about trying...
      Learner
      • weirdlookinguy
        • Sep 2007
        • 1638
        Whatever you end up doing, be sure you only mess with the anti-glare coating. If you accidentally cut into the polarizer (which is directly under the anti-glare sheet), areas with no polarizer will show up as white.
        • capxrf
          • Jan 2010
          • 28
          weirdlookinguy... do you mean that if I have gone all the way to the glass, there will be no image at all in those areas? only white? That isn't the case as of yet. I wasn't aware that would happen. I thought that after the anti-glare there was the actual glass.
          I have thought of polishing the whole thing, but am leaving that as my last resort option, because after that, I have no options. (it will be very time consuming if that's what I do)
          I went ahead and tried roughing up the shiny spots. It was to no avail though. Nothing changed (didn't really rough up at all). I thought this meant I was to the glass, but I guess not if weirdlookinguy said is true.
          Is there a chance the "polarizer is under the glass, and I need not worry about it? (I'm not too familiar with LCD construction I guess)
          good ideas though, any more?
          • kikkoman
            • Jul 2007
            • 691
            you could ask at lumenlab.com. they're into projectot building and mess around with that stuff a lot.
            there's a polarizer on both sides of the glass, so a definite no to that question.
            "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
