Sharp LC-43LBU711C Rev.A wont turn on
  • Trench Recordings
    • Jul 2009
    • 7
    Red power light stays solid red. I've tried power cycling tv and tv remote several times with no luck. So removed the ps board RSAG7.820.8718/ROH part 243900, visually no burnt marks, fuse is fine, no bulged caps. Tested pins and 12V pins reads 9.5V and STB pin reads 0V. Any thoughts on what to check? Should I order another PS board?
    Thanks!
    badcaps.net
  • Trench Recordings
    • Jul 2009
    • 7
    Re: Sharp LC-43LBU711C Rev.A wont turn on
    hmm now after reinstalling the ps board and plugging it in it turned on.
    badcaps.net
    • R_J
      • Jun 2012
      • 9535
      You could check for poor solder connetions on the power supply, check the connections on components mounted to the heat sinks and also the transformer pin connections.
      9.5v on the 12v line would indicate the power supply is working but in standby, It may have also been a poor connection on the cable between the main and power supply boards
      • JunkmanJimbo
        Sharp lc-55p6000u won't turn on
        by JunkmanJimbo
        Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
        09-28-2024, 12:56 PM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • Egidio85
        SHARP LC-40LE814E does not turn on 2 flashes
        by Egidio85
        hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
        the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
        reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
        now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
        to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
        07-21-2023, 11:49 AM
      • Mitike
        SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
        by Mitike
        Hello guys,
        I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
        According to other sharp SM-s it is lamp error (I can't find SM for this model)
        And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
        If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
        02-16-2020, 08:11 PM
      • spantor
        pins for turn on fsp123-3f01 power board
        by spantor
        Hi.
        Could someone tell me which pins to jumper to activate Power board fsp123-3f01. It is from a Grundig TV model 49 vle 6621 wp
        Thanks un avance
        03-02-2024, 10:11 AM
