Sony Trinitron
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Re: Sony Trinitron
    Do you ever fish in that lake behind you there???
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Sony Trinitron
      my trinitron tv KV-X25271D stopped responding to remote. everything else works fine. any ideas about that?
      • Wizard
        • Mar 2008
        • 2296
        Re: Sony Trinitron
        is this correct model?
        Cheers, Wizard
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Sony Trinitron
          Kv-x2571d
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Sony Trinitron
            ok forget it. the remote is the problem. found an old video remote which works.
              • 31294
              Re: Sony Trinitron
              open the remote buy sliding an old credit/fone card along the edges and then resolder the led & resonator.
              very common problem in remotes.
              • tmwalsh
                • Jan 2009
                • 119
                #27
                Re: Sony Trinitron
                Junk, that's Mrs Plainbill in his avatar pic.
                Guy I knew at work told of a hi-volt situation where he had his hand under one board of electronics with all kinds of sharp jabby things hanging down, and he touched a hi voltage connection... his arm jerked his hand back up against all the pins and solder tails whereby it then got jerked back down against the hi voltage. I think he said he slapped it back and forth about 3 times before he could get himself backed out.
                He was a good guy.
                Thing with hi voltage is to keep one hand securely tied to a pocket. That way you never have the current pass from one arm to the other arm - through your heart. Not good. I work on a table that is not made of conductive material, and so far have not zapped anything by powering up the circuits on the table or on their side. The most worked on set has a sound board standing up on the left side of the chassis that is perfect to hold the chassis vertical. Thing is, solder tends to follow gravity...
                tom
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Re: Sony Trinitron
                  Sorry about that Plainbill. I told you all I can't see worth a fudge!
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: Sony Trinitron
                    Lake? Sonny, that's the Pacific Ocean! And no, never have. But my grandson like to fish.
                    PlainBill
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Re: Sony Trinitron
                      "and then resolder the led & resonator.
                      very common problem in remotes."
                      ESPECIALLY after you've sat on, slept on, dropped or thrown them...
                      veritas odium parit
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        #31
                        Re: Sony Trinitron
                        that worked thanks
                        • smason
                          • 1652
                          Re: Sony Trinitron
                          Or if your Retrievers have retrieved them a few times.....
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            Re: Sony Trinitron
                            Sorry again PlainBill. Since I'm over here on the wild wonderful polluted Atlantic all the other oceans look like lakes to me....LOL Only kidding Mate. I hope to do some fishing out in your lake someday. How many fish has your Grand Son caught in your cement pond?
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • motorahead
                              Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                              by motorahead
                              Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                              After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                              10-21-2023, 03:50 PM
                            • ptcriserx3
                              Sony trinitron crt bowed and side color issues
                              by ptcriserx3
                              Hi
                              Ive got a vintage 2001 sony trinitron flat tube tv
                              The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                              See many images attached...
                              Just windering if this is not fixable or something i can correct without getting too invloved
                              Im trying to sell the tv
                              06-17-2023, 07:27 PM
                            • Flaku_34
                              Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                              by Flaku_34
                              Introduction:
                              Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                              04-18-2024, 12:47 PM
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • sickboy
                              Strange CRT Fault (Sony Trinitron M1410U)
                              by sickboy
                              This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                              11-10-2024, 05:02 AM
