Hisense 49H3E standby light on but will not turn on
  • frannyjunk
    • Oct 2010
    • 78
    I've taken the back cover off and there is only 1 board. I unplugged the LED wire and connected it to a backlight tester, resulting in the backlights turning on and the tester reading 60V. This tells me that the backlights are OK. I then cooled the EEPROM (UF1) with canned air, but the TV still only has a solid standby light and will not turn on. Other than the EEPROM, is there a "common" component that fails on these single board TVs? It looks like many of the budget brands use the single board approach (many using the same board, # TP.MS3393.PB851, but I am sure with different EEPROMs). Could it still be an EEPROM issue?
  • naack
    • Dec 2021
    • honduras
    Re: Hisense 49H3E standby light on but will not turn on
    i have the same board with the same problem. any progress on this device?
    i just started on it now. i will update if i find anything
    • lotas
      • Jan 2016
      • 4592
      • Russia
      У вас есть программатор, чтобы считать данные с SPI Flash?
      • dskall
        • Oct 2016
        • 2905
        • usa
        unplug your tv. Use your upgrade plug on board. Apply 12v and see if you get your power light and see if it powers on. You can use a flashlight to see if you have an image on screen.
        • R_J
          • 9535
          If you are going to freeze the eeprom, the tv must be unplugged at the time. Unplug tv, freeze eeprom, wait a few seconds, then plug in the tv and try turning it on. You may need to try this a few times for it to work.
          The eeprom is read when the tv is first plugged in, freezing it after will have no effect.
