Hisense 49H3E standby light on but will not turn on
  • frannyjunk
    • Oct 2010
    • 82
    I've taken the back cover off and there is only 1 board. I unplugged the LED wire and connected it to a backlight tester, resulting in the backlights turning on and the tester reading 60V. This tells me that the backlights are OK. I then cooled the EEPROM (UF1) with canned air, but the TV still only has a solid standby light and will not turn on. Other than the EEPROM, is there a "common" component that fails on these single board TVs? It looks like many of the budget brands use the single board approach (many using the same board, # TP.MS3393.PB851, but I am sure with different EEPROMs). Could it still be an EEPROM issue?
  • naack
    • Dec 2021
    • honduras
    Re: Hisense 49H3E standby light on but will not turn on
    i have the same board with the same problem. any progress on this device?
    i just started on it now. i will update if i find anything
    • lotas
      • Jan 2016
      • 4744
      • Russia
      У вас есть программатор, чтобы считать данные с SPI Flash?
      • dskall
        • Oct 2016
        • 2905
        • usa
        unplug your tv. Use your upgrade plug on board. Apply 12v and see if you get your power light and see if it powers on. You can use a flashlight to see if you have an image on screen.
        • R_J
          • 9588
          If you are going to freeze the eeprom, the tv must be unplugged at the time. Unplug tv, freeze eeprom, wait a few seconds, then plug in the tv and try turning it on. You may need to try this a few times for it to work.
          The eeprom is read when the tv is first plugged in, freezing it after will have no effect.
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • Jackching
            Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
            by Jackching
            I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
            04-15-2024, 05:14 PM
          • PNI E.
            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
            by PNI E.
            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
            03-17-2025, 04:23 AM
          • EUWest
            Hisense rsag7.820.5687 no power no standby light
            by EUWest
            Hi!
            I have a power supply and on the TV no standby and no power. Have already installed a replacement power supply but the same problem.
            When I test both power supplies the main capacitors while plugged in, I get 0v.
            What could be the reason for this?...
            04-14-2023, 08:59 AM
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
