T-con test pattern jumpers
  • thepiecesfit
    • Apr 2021
    • 8
    Greetings I'm trying to make jumpers to run the tcon test patterns below but my LG OLED does not list 3.5v on p201 which pins would I use?
    3.5v to P_ON
    3.5v to 12VT_ON
    3.5v to DRV_ON
    Image below
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: T-con test pattern jumpers
    The picture does not show part of the t-con and I'm not sure if a oled t-con has a built in test patern generator. Maybe when you push the P-only button on the service remote. I wonder why you want to run a testpicture , is there a problem?
    • thepiecesfit
      • Apr 2021
      • 8
      It's a picture of the power board connector pins that were suggested for creating jumpers in another post to trigger t-con test patterns while the mainboard is disconnected. I'm trying to determine if my panel is at fault. The tv sends an sos to shut off when the mainboard is connected to the tcon. When the mainboard is disconnected the power stays on fine. I'm at a loss on what to try next, t-con, power and mainboard were also all replaced.
      • budwich
        • Jul 2015
        • 3097
        Is is possible that you misunderstand what to jumper where. As suggested look at the tcon for equivalent labelling. Perhaps there is the voltage that you need AND is provided at the tcon itself from power that it gets from the power board.
        • William1967
          • Nov 2017
          • 217
          • Netherlands
          The old plasma tv's had that option, an Oled does not. A LG Oled service remote has a P-only button to start up the tv without the mainboard.
          • thepiecesfit
            • Apr 2021
            • 8
            Got it there was a user on this board suggesting this on an OLED in multiple posts. Thanks for clarifying.
            • Maykel
              • Oct 2021
              • Cuba
              Hello ,I have the same issue in my lg oled 55E8 do you find some solution to your problem ,please answer to this email myk7706@gmail.com, thanks
              • thepiecesfit
                • Apr 2021
                • 8
                Sorry but no, nothing worked. The panel had to be replaced.
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • nono34
                  Hisense stuck in Colors cycle like test pattern.
                  by nono34
                  I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                  I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                  10-24-2024, 04:31 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
