Replacing Main Board on One Connect Samsung
  • NizNoz
    • May 2021
    • 43
    Hi. I'm busy troubleshooting my Samsung Frame TV UN65LS003 on another thread, but I had a separate question I'm hoping someone here may have an answer for.
    The service manual states that after replacing the main board you should "change the factory option. The options you must change are 'Type'." I've linked the service manual (page 57). It also states you should "change option bytes when replacing Main Board".
    The only change I made was going to service menu -> Option -> Type -> 65A1AUOKM
    That's all I did. I checked firmware was updated (it was). My intermittent issues continue as before. Is there something else I need to do to "change option bytes"?
  • R_J
    • 9588
    Re: Replacing Main Board on One Connect Samsung
    The service manual refers to when you get a NEW board from Samsung for replacement, not a used board.
    • NizNoz
      • May 2021
      • 43
      So for replacing with a used board you don’t really need to change anything?
      I had swopped boards and wondered if not setting the option bytes was why the original issues persisted.. https://www.badcaps.net/forum/showthread.php?t=95666
      • NizNoz
        • May 2021
        • 43
        Could you maybe clarify something for me please? I notice on my service menu the "Option" parameter is set as "65A1AU0KM,...,...,NONE"
        The service manual lists the following information under "Factory Option" settings: BOM = 003, Local Set = US, Type = 65A1AU0KM (and a bunch of other default settings).
        Is it safe to say I'm fine leaving these settings alone? It seems technicians hardly ever need to change these settings. Just need some reassurance I'm covering all my bases for troubleshooting. Thanks!
        • R_J
          • 9588
          If you want to change those settings you will need the Factory Remote (pdf, page 56)
          • NizNoz
            • May 2021
            • 43
            I've been using the generic, IR remote to access the service menu. I take it you mean some of the options mentioned are only accessible with the official, service remote, right?
            I noticed the setting "Deadkill Lock" was ON. Any idea what that does? Everything else seems default (apart from what I changed).
            • R_J
              • 9588
              I don't know what Deadkill Lock is, It might be used when the panel is setup or tested, it is under the DEBUG heading. The remote that comes with the tv has LIMITED OPERATION, to adjust some options you must have the SERVICE REMOTE AA81-00243A, or I believe there is also a apk file you can use on a smartphone to sub for the service remote. Be careful what you change or you might end up buying another main board.
              • NizNoz
                • May 2021
                • 43
                Thanks, and noted. Have you by any chance ever heard of Serdes
                Errors? My error count page has 255!
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  https://www.samsung.com/us/support/t...g/TSG01109041/
                  This suggests your problem is the cable not any of your boards, unless you were changing the one connect for another reason.
                  • NizNoz
                    • May 2021
                    • 43
                    Thanks.. I hadn't actually seen Samsung describing intermittent issues like this caused by the cable. I guess that leaves two possibilities. The box and the cable. Pity they're so expensive to source Having said that, I'm gonna take a careful look at the cable. Maybe there's something visibly wrong. That should help.
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • madyoyo
                      Samsung UE43J5500: Replacing main board by another model or screen size
                      by madyoyo
                      Hi everybody;
                      The main board (bn94-09121q) on my UE43J5500 is dead. I can't find the exact same board for a reasonable price, but some other part numbers are pretty cheap, they are physically identical, and based on the bn41-0235 board
                      Can i swap the bn94-09121q by another "letter", like a bn94-09121N, or even from anoter screen size?
                      12-27-2022, 04:15 PM
                    • C152Heavy
                      by C152Heavy
                      Summary for TL-DR readers:
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
