Samsung UE43J5500: Replacing main board by another model or screen size
  • madyoyo
    • Aug 2018
    • 12
    • france
    Hi everybody;
    The main board (bn94-09121q) on my UE43J5500 is dead. I can't find the exact same board for a reasonable price, but some other part numbers are pretty cheap, they are physically identical, and based on the bn41-0235 board
    Can i swap the bn94-09121q by another "letter", like a bn94-09121N, or even from anoter screen size?
  • nomoresonys
    • 12268
    • U.S.
    Re: Samsung UE43J5500: Replacing main board by another model or screen size
    what is the full model code on the back cover of tv?
    • Rajnhl
      • Oct 2018
      • 94
      • India
      you can use any board that supports panel's resolution. most board support lvds mapping setting and mirror image setting in service menu.
      • madyoyo
        • Aug 2018
        • 12
        • france
        eu-43j5500awxzf
        • nomoresonys
          • 12268
          • U.S.
          not 100 percent sure, but I think that bn94-09121N will work for you.
          • alfatv
            • Sep 2020
            • 353
            J series service menu has a long list of panels, so just find yours and select it. Especially if image is upside down, you need to go through this step.
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
