Thorn 65thl4kst1
  • viewerau
    • May 2020
    • 305
    Re: Thorn 65thl4kst1
    Ok, I used a number of ways.
    Plug out, nothing connected 0/0
    Plug in,tv on standby 031/031
    Plug in, pressed power on remote 1997/1997...this slightly fluctuated down and back up between 1958 and 1997 on both sides
    EDIT
    I have checked all ribbon cables to make sure they are seated correctly. Touching or wiggling them does not make any difference, still just the white screen.
    Signature:Seemingly hopeless tv fixer
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      #42
      If you are on the 20 Volt dc range then the maximum reading will be 19.99V and minimun would be 0.01V so I don't understand where the 1958 is coming from unless you mean it's 19.58V and 19.97V?
      • viewerau
        • May 2020
        • 305
        This is the numbers that my digital readout show.
        It does not indicate any decimal point .
        It is set on the 20 position
        Perhaps, as my Meter is very old, that is the reason?
        • viewerau
          • May 2020
          • 305
          The 1957/1958 etc is a number that will not completely settle whilst I hold the red probe on each end of the fuse. It does not ever sit on one number.
          I assume it is saying 19. something volts?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            #45
            At this point I do not trust your multimeter so first can you check any 9V batteries you may have and see what it reads otherwise I would try another multimeter.
            • viewerau
              • May 2020
              • 305
              Thanks for the continued help...I will get another multimeter tomorrow.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #47
                Or put new batteries in the one you have and then check any 9V battery you have to hand.
                • viewerau
                  • May 2020
                  • 305
                  Sorry, I am back again.....
                  I purchased a brand new multimeter..
                  Nothing plugged in, no power no nothing 0/0
                  Power plug in, set on standby 0.06/0.06
                  Power plug in, click power on remote, both sides 12.07/12.07
                  Can this help us better....
                  • viewerau
                    • May 2020
                    • 305
                    OK....I have just noted something after taking a close up photo of my led driver board on this telly, blowing it up to look at on my pc, and comparing it with one for sale online.
                    The image on the left is a board for sale on the net. The image on the right is my board.
                    Could it be work has been done on this led driver board on mine, by the look of all the solder and the caps sitting on an angle etc?
                    Is there a method I can use with my meter to put it on a setting and seeing if it is behaving correctly.
                    Or am I off target as usual?
                    Thank you again.
                    edit...
                    I found another clean picture of a same board for comparison...thanks
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      #50
                      The picture of your board is too dark to make a good comparison although the amount of flux around the capacitor on your board does appear to suggest it has had some work done on it.
                      The 12V on the Tcon both sides is fine confirming that you have power to the tcon board.
                      • viewerau
                        • May 2020
                        • 305
                        Enlarged photo
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #52
                          Post #1 Initially you say that the service engineer said it was a faulty mainboard and you were looking for advice on a replacement mainboard.
                          In post #15 you mention that you have put a replacement mainboard in and also say the Tcon board has extra letters...... So have you changed the original Tcon?
                          The pictures are too dark to be able to compare them. "TV powers to on, but the screen is just white...grrrr" so the backlights are working.
                          Post# 28 You confirm that you have sound
                          Post #48 Finally confirm that the Tcon has a 12V supply at both ends of the fuse.
                          Post #49 You mention there may have been some work on your led driver board. But if you have a white screen then the backlight led driver board is working.
                          Could you pictures of the original / replacement tcon and original mainboard / replacement mainboard as bright and clear so as to read any text on them.
                          • viewerau
                            • May 2020
                            • 305
                            Original Mainboard replaced from a working exact same model Thorn tv, via ebay seller...all numbers match
                            The T-con board in this tv is the original one...never removed since it has been here...only ribbon connections and power on fuse checked.
                            White screen still glows when telly turned on.
                            I don't know what to do now...
                            EDIT
                            Again dark now, so will photo both the original mainboard as well as the one purchased, tomorrow, in better light.
                            • viewerau
                              • May 2020
                              • 305
                              Original Board photos
                              • viewerau
                                • May 2020
                                • 305
                                Replacement and now fitted board
                                • viewerau
                                  • May 2020
                                  • 305
                                  Sorry, forgot to add the photo of my t-con
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #57
                                    The main boards do look identical.
                                    There are a number of test points on the Tcon but they are difficult to make out from the photos.
                                    The ones I can see are HVDD, VGL2 & VCC18. Can you measure the voltages at those points to start with.
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Thanks again,
                                      I will test these again in the morning.
                                      Do I put the meter on 20 again and negative to chassis?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        #59
                                        Yes, That's fine. Keep an eye out for the "-" sign on your meter indicating a negative voltage.
                                        • viewerau
                                          • May 2020
                                          • 305
                                          HVDD...reads 0.00 to -0.01
                                          VGL2....reads 0.13 to 0.15
                                          VCC18..reads 0.00 to -0.01
                                          meter set on 20, negative to chassis, positive to check point. Panel powered to on.
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • qwerty99
                                            Xbox 1.6 Motherboards and Polymer Capacitors
                                            by qwerty99
                                            Hello!
                                            I need to change the capacitors on my three original Xboxes.
                                            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                            06-26-2022, 12:53 AM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • matthewmcconaughey
                                            I need help with my friend Sony GDM-FW900 24” CRT
                                            by matthewmcconaughey
                                            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                            1. It started with a bright and greenish picture upon starting a cold monitor.
                                            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                            05-16-2023, 03:15 PM
                                          • Jackching
                                            Intel PC hooked to X90L television picture cut-off
                                            by Jackching
                                            I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                            10-27-2024, 11:43 AM
