TCL 43" Model 43S525
  • BradW
    • Sep 2020
    • 13
    Was given this new TV that has backlight but no picture.
    - When both T-Con ribbon cables that run down to the driver boards are
    connected, I get no picture - just backlight.
    - When I remove the left-side ribbon (facing back of TV), no picture.
    - When I leave the left-side connected and remove the right-side ribbon cable, I get a good image on the right-side of the screen. Seems to be exactly half the screen.
    - I've swapped ribbon cables and there's no change so I know the ribbon are good. I've inspected the T-Con and driver board and don't see any obvious burnt or missing components. (not that I expected to)
    QUESTION: Is it more likely that the problem is with the T-Con board or the driver board? OR, is it anyone's guess?
    Any suggestions on further troubleshooting? Do I start looking for shorts, etc.?
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL 43" Model 43S525
    Backlight but no video tcon is first suspect and boards are usually fairly inexpensive. You can try connecting one side at a time between tcon and panel. If one side is good, you have a fault in the panel on the bad side.
    • BradW
      • Sep 2020
      • 13
      I did try that.
      If I disconnect left side cable (from T-Con to driver board), I get a good picture on right side of screen.
      If I connect only the right side, I get nothing on any part of the screen, just backlights.
      Does this mean bad panel or something on the driver board?
      • neilc6
        • Nov 2015
        • 1550
        If you get a good image on one side, it means the tcon is good and there is a fault on the bad side. You can try blocking some pins from the tcon on the bad side with the tape cutoff method.
        https://techhometravel.com/repair-of...lines-on-a-tv/
        Sorry only scanned your original post. Assumed you didnt test one side at a time. You should have posted pics of the screen.
        • BradW
          • Sep 2020
          • 13
          I'll post pictures of the screen in the next day or two and also try the crazy tape cutoff method. Learned a lot watching those videos in the link you sent. Thanks.
          • vinceroger69
            • Mar 2012
            • 6714
            On the bad side of the lcd panel board check for any shorted smd capacitors i have seen a few sets with bad smds causing this issue
              • 12096
              • U.S.
              on the bad side of the lcd panel board check for any shorted smd capacitors i have seen a few sets with bad smds causing this issue
              +1
              • BradW
                • Sep 2020
                • 13
                Sorry only scanned your original post. Assumed you didn't test one side at a time. You should have posted pics of the screen.
                neilc6, I watched some videos and did the tape cutoff method and narrowed it down to one clock signal line. Once I taped off just that one line (like doing micro-surgery), the TV looks perfect.
                Thanks a million. I never would have known about that method.
                • neilc6
                  • Nov 2015
                  • 1550
                  The other issue you may encounter with Roku TVs is the default backlight settings will burn them out so you should turn it down.
                  https://techhometravel.com/turn-down...l-in-roku-tvs/
                  • BradW
                    • Sep 2020
                    • 13
                    Yes, I tell everyone the same. Most TV repairs you see on youtube are backlight issues.
                    This TV went to my nephew and the first thing he said was that he hates a bright TV so he turn backlight/brightness down low.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Brilliant work nice one
                      • Joetiii
                        • May 2022
                        Ok so the tape method worked for me though I have some questions. Right now I have 8 or 9 pins covered and the screen looks as it did before it went blue. No horizontal lines that I can see. Should I go through and try to eliminate pins one by one? Or can I leave as is?
                        How long does this fix last?
                        What am I missing on screen with all the 8 pins covered?
                        Thanks in advance for your thoughts on this.
                          • 12096
                          • U.S.
                          check the video that says 4k tv fixed in the link in post #4.
                          • osrex
                            LED DRIVER KEEPS DYING
                            by osrex
                            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                            i have no datasheet at all for the LED lights, all i have is its length.
                            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                            05-05-2025, 03:36 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • MoreMagnets
                            Sony KD49X8000H - Sound, backlight, no picture
                            by MoreMagnets
                            Hello all!
                            This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                            Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                            10-23-2022, 09:31 PM
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • Daren87
                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                            by Daren87
                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                            08-13-2023, 03:25 PM
