Samsung UE55ES7000
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Samsung UE55ES7000
    This samsung is having vertical colored lines
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Samsung UE55ES7000
    Ps51f4500-?
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      No is not a plasma. Is an led smaet tv
      • mmartell
        • Oct 2013
        • 3189
        Really ? It says "Plasma" right on the label. You must have posted the wrong label pic.
        • hispeck
          • Aug 2015
          • 258
          • nigeria
          Am very sorry please. The model is UE55ES7000
            See Samsung Fast track.
            Inspect the connectors.
            • jjanssen7
              • Nov 2012
              • 252
              if you look at the bottom of your display, it looks like all off the screen starts to drop out/no display. I'd look for moisture damage on the driver boards between the screen and the tconn?
              • hispeck
                • Aug 2015
                • 258
                • nigeria
                I have inspected up to the sceler board, i didn't see any damage. Am suspecting the cof ic. And the ic's are 14 in numbers . 7 each side. And if you look at the screen only corner is having good picture. So am asking if i replace the rest about 13 chips if it will work ?
                • mmartell
                  • Oct 2013
                  • 3189
                  You want to replace the COF's ? Not sure if anyone here has tried that...
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • Maverick1234
                    Colored Vertical lines on Samsung UN55C6400RF TV
                    by Maverick1234
                    I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
                    Thanks,
                    Sanjay
                    09-13-2021, 02:43 PM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
