firmware for sony KDL40X 3500
  • Diah
    • Feb 2013
    • 6365
    Re: firmware for sony KDL40X 3500
    how the Fans spins at start up? fast or slow??
    at self test remain the screen ON?
    EDIT: it tell T-CON issue.. can we see yours t_CON
    • jimbofz
      • Apr 2013
      • 539
      sometimes at start up you hear fans fast ,but not always ,
      sometimes they dont spin at all.
      it looks like t con error
      even though there is nothing wrong with the picture
      this is what puzzles me
        • 12179
        • U.S.
        Maybe check all the voltages you can on the tcon.
          • 12179
          • U.S.
          There's some good tcon troubleshooting guides on here somewhere.
          • Diah
            • Feb 2013
            • 6365
            okay, how about you keep the 2 fan you tested with connected... and log in diagnostic mode again with out any signal feed... clear the puffer error, then plug it out from wall for 10 minute and in again with out any signal, just call the menu.. let see how long it will remain displaying the menu
            EDIT. same way you can log in service menu and from there make hard reset.
            • jimbofz
              • Apr 2013
              • 539
              #26
              to clear the buffer error ,
              is that when in service mode ,press 8,mute,0
              is that correct?
              or,
              in diagnostic mode ,press,8,mute,0
              • Diah
                • Feb 2013
                • 6365
                diagnostic mode
                • jimbofz
                  • Apr 2013
                  • 539
                  #28
                  followed your instructions,
                  now the menu stays on much longer about 3 minutes
                  before it returns to 5 blinks the menu looks darker than normal
                  (this is without any signal i/p)
                  • Diah
                    • Feb 2013
                    • 6365
                    so you have now approve with less load ---> long time ON.
                    beside you stated early about the Fans Spin "sometimes they dont spin at all."
                    from my know T-CON would not got this behavior if there component defect at Boards. unless it sound to me, that you need to focus on the 12V supply as other asked before. dropping this supply cause Menu darker. also if you repeat the last test you did, but now with half screen ( one side ribbon disconnected ) i think the 3 minutes time will increase.
                    • jimbofz
                      • Apr 2013
                      • 539
                      #30
                      good morning and thanks again for your help the psu derrived 12v is spot on theres no ripple on scope .
                      there are 4 ribbon cables to panel
                      should i remove two on left
                      then try two on right?
                      • Diah
                        • Feb 2013
                        • 6365
                        sure , as there 4 ribbon so need 2 per side at time.
                        • jimbofz
                          • Apr 2013
                          • 539
                          #32
                          ok ,itried 2 per side as suggested no change
                          so as you sugested i had a close look at 12v supply.
                          first it goes to logic board and is 12.1v
                          then it goes through 8 pin ic type tcp 8109 q7403
                          the i/p to this is 12.1v but o/p is 11.4v ,
                          pin4 of this device is a control pin
                          so the volts that arrive at t con are low just as you said .
                          after checking for any low resistances , none found .so i unplugged connection from logic board to t con and voltage came up to 12v as you would expect under no load
                          please see cct ub1 board page 155 bottom right corner
                          try to upload cct for some reason wont work will try again
                          • jimbofz
                            • Apr 2013
                            • 539
                            #33
                            heres the cct diagram
                            • jimbofz
                              • Apr 2013
                              • 539
                              #34
                              the two 47uf on the i/p to q7410 replaced
                              the 4.7uf on the o/p c7455 replaced
                              • jimbofz
                                • Apr 2013
                                • 539
                                #35
                                heres some pics of tv in diagnostic mode with TEMPORARY link across i/p and o/p of q7403 8 pin device mentioned above
                                pic 4 shows why its worth trying to save it from landfill
                                it still goes off with 5 blinks after a few minutes
                                • Diah
                                  • Feb 2013
                                  • 6365
                                  on page 18, did you try :
                                  1- reset ( setting shipping condition ) ?
                                  2- at same page 3-8-5 T_CON error ( point No 1 ) i cant trace it on the manual pdf. as my screen non PC
                                  & let see yours T-CON how its look
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    #37
                                    1 yes i tried reset shipping condition
                                    2 the advice sony give is :check BE micro pin 128 on fb2 board
                                    replace board
                                    i tried to find correct pin of this ic to see if pin 128 was going high or low when fault occurs
                                    but i couldnt be certain which was pin 128 on this 176 pin ic and didnt want to short out any pins with my mini meter probe
                                    i will post pics of the logic board and the t con
                                    but im now thinking fault is caused by logic board dropping the 12v supply voltage ,as the 12v goes first to logic board then to t con
                                    you will see in pics that i removed 10 amp fuse and fitted 5 amp jumper wire ,.this is only during fault finding and correct fuses will be fitted when i finally sort this fault so dont be alarmed i have new correct fuse ready to fit
                                    • Diah
                                      • Feb 2013
                                      • 6365
                                      let us clear one things... did you find F1 on T-CON Open before??
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        #39
                                        yes
                                        • Diah
                                          • Feb 2013
                                          • 6365
                                          yes
                                          check this IC short you have on 2 pin as the photo remarked.
                                          • tec3000
                                            Sony LED 65X9005A shuts down after few seconds - looking for help
                                            by tec3000
                                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                            03-20-2024, 07:29 AM
                                          • joby91
                                            SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                            by joby91
                                            I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                            I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                            I found one chat about firmware on ************** forum but i cannot read the comments.
                                            https://**************/forum/108-114100-1#880537
                                            09-04-2024, 01:34 PM
                                          • jason123
                                            Sony Firmware for XBR-70X850B
                                            by jason123
                                            Hello
                                            Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                                            I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                                            Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                                            Much appreciated.
                                            05-17-2022, 12:42 PM
                                            HP Pro 3500 Pro 3500 G540 Specification for Upgrade or Repair
                                            This specification for the HP Pro 3500 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro 3500 boardview and Pro 3500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro 3500 is accurate,...
                                            09-12-2024, 03:36 PM
                                            HP Pro 3500 MT Pro 3500 G2020 Specification for Upgrade or Repair
                                            This specification for the HP Pro 3500 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro 3500 MT boardview and Pro 3500 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro 3500...
                                            09-12-2024, 03:30 PM
