firmware for sony KDL40X 3500
  • jimbofz
    • Apr 2013
    • 539
    my sony has great pic and sound for 6 seconds then ,5 blinks
    which usually means bad t con or lvds cable.or on this model logic board
    given that the pic is good ,i suspect corrupt f/w
    sony website no longer has f/w for this model .
    ive searched the net no luck ,
    according to the service manual f/w update is possible with usb on this model
    i was able to enter service menu and quickly do factory reset (press 8,mute,0, power on)
    but micro still turns off after 6 seconds
    .tried powering on with sby button on tv pressed, no luck
    sorry for repeating a post on this model but the previous post was related to problem with backlight which is now ok
    for me this tv has become quite a challenge
  • Diah
    • Feb 2013
    • 6410
    Re: firmware for sony KDL40X 3500
    as i know this set had cooling Fan / Fans ... at your first threat (https://www.badcaps.net/forum/showthread.php?t=92081 ) of this set i didn't see any Fan !!!! ???
      • 12212
      • U.S.
      There was a recall, wonder if they can at least help you with the firmware, like direct you to where it is or send it to you??:
      Sony: Product recall
      IMPORTANT : if you own one of the following models: SONY KDL-40D3500 , SONY KDL-40D3550 , SONY KDL-40V3000 , SONY KDL-40W3000 , SONY KDL-40X3000 , SONY KDL-40X3500 or KDL- 40D3400, KDL-40D3660.
      Then you must contact Sony in order to carry out a free control of your TV following a component which could be defective and generate overheating and ignition of the product.
      Click here for details of the terms and conditions.
        • 12212
        • U.S.
        Recall was quite a while back but it seems like they wouldn't want them catching fire, no matter how long ago it was.
          • 12212
          • U.S.
          The updated firmware was also suppose to quiet down the fans. NOT to be confused with the recall, which was for faulty component/s.
          • jimbofz
            • Apr 2013
            • 539
            yes my set does have two fans .
            apparently the f/w upgrade was to make the fans quieter as original owners complained about the noise they made
            ive trawled through sony website to see if i can contact them ,
            but you go round in circles there doesnt seem to be any way of e mailing them about this
            perhaps these older models they no longer want to help you with
            the website is designed to prevent any contact with them
            • jimbofz
              • Apr 2013
              • 539
              i think if the fans dont work ie the set running too hot the error is 7 blinks
                • 12212
                • U.S.
                Deos seem so, maybe a member here has a good phone number or good contact info for them.
                • jimbofz
                  • Apr 2013
                  • 539
                  thanks fingers crossed
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    https://services.sony.co.uk/supportm...ectors-lcd-tvs
                    maybe worth filling in this form and seeing if they will provide you with the firmware no harm in asking i guess
                    • Diah
                      • Feb 2013
                      • 6410
                      yours first post and this you described same issue 6 seconds perfect picture then out.. its fan spins problem not firmware... put new PC fan or clean the shift of the original.. we discussed this before, when spins low resistances will rise result tv shutdown to protecting.
                      • jimbofz
                        • Apr 2013
                        • 539
                        ok done that will wait to see if they get back to me
                        just wondered if there is any way to desensitise the protect cct
                        to see if anything draws too much current
                        one thing i tried was to run the t con and logic board via external 12v bench supply
                        which i had previously frozen with freezer spray
                        then applied 12v and looked closely to see which conponent thawed first ,all components stayed frozen for same time so this was inconclusive
                        on the logic board (the pre t con) there were a number of caps that esr value were suspect so i replaced them and checked for any s/c sadly no luck
                        • jimbofz
                          • Apr 2013
                          • 539
                          thank you Diah ,
                          once again you have come up with something i did not consider
                          mainly due to the number of blinks being 5 not 7
                          • jimbofz
                            • Apr 2013
                            • 539
                            ok unplugged both fans ,still 5 blinks not 7
                            heated up tv with hairdrier tried again ,still 5 blinks
                            removed fans ,tested with 12v supply ,both fans spin with very low current drain .
                            measured resistance of each fan and compared with similar 3 pin fans all measure the same
                            could there be some temperature sensor faulty ?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              does this work?
                              1. In standby mode, press the following buttons on the Sony remote:
                              DISPLAY....5....VOL(-)....TV POWER
                              2. On the left side are the blink codes. On the right hand side is the error count.
                              3. Under 005, you'll see three listings... TCON, HFR, and P-ID (pane
                                • 12212
                                • U.S.
                                Is there 12 volts at the connectors of the fans, you know so they are getting 12 volts?
                                • Diah
                                  • Feb 2013
                                  • 6410
                                  1- set with out Fan connected will not work
                                  2- yours way of testing sorry to say wrong... no need to heat or any other... you have spins issue.. you need to Oil the shift of the original.. see if the shift fits exactly and there no play move on sides . put pc fan and switch on.. your set will working.
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    thanks ,i cleaned and oiled the original fans , same fault
                                    i removed them
                                    and replaced them with some from an old hitachi plasma
                                    same 12v ,3 lead type but just bigger in size.
                                    .same fault see pic (.i left them hanging over the top )
                                    the pic is blurred because i dont have enough time for camera to focus before tv goes off to 5 blinks
                                    during testing i use scart i/p as this usually means tv will auto select scart and i always get sound
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      does this work?
                                      tried what you suggest but not enough time before 5 blinks ,i will keep trying
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        does this work?
                                        ok i found if i switch to analogue and remove all i/p
                                        i can get in to self test mode:
                                        005 t con 2103081859
                                        007 temp error 0000000000
                                        009 fan error 0000000000
                                        008 auto prot 0000000000
                                        013 ballancer 0000000000
                                        i tried to take a pic but it was barely readable .
                                        whats interesting is that it doesnt show all the 002 to 013 codes every time
                                        but the only thing showing any error is 005
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • tec3000
                                          Sony LED 65X9005A shuts down after few seconds - looking for help
                                          by tec3000
                                          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                          03-20-2024, 07:29 AM
                                        • joby91
                                          SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                          by joby91
                                          I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                          I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                          I found one chat about firmware on ************** forum but i cannot read the comments.
                                          https://**************/forum/108-114100-1#880537
                                          09-04-2024, 01:34 PM
                                        • jason123
                                          Sony Firmware for XBR-70X850B
                                          by jason123
                                          Hello
                                          Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                                          I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                                          Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                                          Much appreciated.
                                          05-17-2022, 12:42 PM
                                          HP Pro 3500 Pro 3500 G540 Specification for Upgrade or Repair
                                          This specification for the HP Pro 3500 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro 3500 boardview and Pro 3500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro 3500 is accurate,...
                                          09-12-2024, 03:36 PM
