Samsung tv le40d550k1w solarized problem
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Re: Samsung tv le40d550k1w solarized problem
    Hello again
    I finally measured the trends to draw a conclusion about the Gamma, I believe that the measurements are good, I would just like someone experienced to confirm it
    I have a doubt about Vcom on my Tcon board 31T09 -Col T315HW04 VB part number 5540T04C12 I did not find a VCom point only VGNDE and I measured it in terms of ground (chassis of the TV) 0volt but if this point is the same as the potential of the earth it seems logical but I can not to understand how else VCOM can be mentioned.
    The other trends I have always measured in relation to the chassis
    of the TV are
    VGH 28VOLT
    VGL -6VOLT
    AVDD 15.84VOLT
    VG1 15.14VOLT
    VG2 14.83VOLT
    VG3 12.43VOLT
    VG4 10.9 VOLT
    VG5 9.84 VOLT
    VG6 8.63 VOLT
    VG7 8.51 VOLT
    VG8 7.51VOLT
    VG9 7.12VOLT
    VG10 5.35VOLT
    VG11 4.61VOLT
    VG12 3.325VOLT
    VG13 0.657VOLT
    VG14 0.35VOLT
    in addition the complete one that is responsible for Gamma was relatively cold in no case did it heat up
    What do you think of ordering a new Tcon?
    • diif
      • Feb 2014
      • 6978
      • England
      The gamma voltages are off. VG6-VG9 and VG13.
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        I can not understand sir how you came to this conclusion but I will look for it according to the .xls file you have given in the forum
        So I have to get another Tcon board because it has a problem
        Thank you very much for your help
          • 12187
          • U.S.
          How so? I don't see a problem with the gammas.
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            Really ? I was confused now the only trend I could not find was Vcom I measured one that said Vgnde which I thought was this
            As for Gamma now after two different points of view I am in a dilemma because I find my own part number only from America and it will cost a lot so I wanted to be sure
            What do you suggest I do?
            • Xristakis795
              • Mar 2021
              • 162
              • Greece
              #26
              this is the graph of gamma in relation to the trend does not seem to me and so linear do you agree that you are more experienced? or
              does it seem normal to you?
                • 12187
                • U.S.
                #27
                Looks fine to me, if there's a problem I don't see it.
                • Xristakis795
                  • Mar 2021
                  • 162
                  • Greece
                  #28
                  thank you sir for your opinion but if you are right then unfortunately it is the panel
                  I have changed mainboard as I mentioned above I have cleaned and reinstalled cables I have done factory reset firmware upgrade I hoped it was Tcon board
                  But as it seems from the measurements, it is probably Panel if you are right and not Mr. Diif, so the repair is not worth it
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #29
                    It's supposed to be a straight line between the first and last point. It clearly isn't.
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      #30
                      Just because in a video from the shop Jimmy I saw it says that if you have distorted colors in the menu when you have a solarized problem it is Tcon and my own TV has distorted colors and in the menu I will probably buy a Tcon and whatever happens
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        #31
                        have you tried setting the colours in the menus ? start at black and white .
                        • Xristakis795
                          • Mar 2021
                          • 162
                          • Greece
                          #32
                          yes whatever I tease brightness contrast etc has no effect
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            #33
                            i have had one with a bad tcon ic and it was almost possible to adjust to a watchable picture .
                            • Xristakis795
                              • Mar 2021
                              • 162
                              • Greece
                              #34
                              in my case that adjusting and making the image is distorted
                              Do you remember what adjustments you made in your case and the image improved?
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                #35
                                turned the colour down mainly .. and contrast i think .was a while back now
                                • Xristakis795
                                  • Mar 2021
                                  • 162
                                  • Greece
                                  #36
                                  I did it without result, however, thank you all for the help
                                    09-07-2024, 05:50 AM
                                  • Rusenga
                                    Samsung PS43E450A1R Picture Problem
                                    by Rusenga
                                    Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
                                    Note the green light on the tcon flashes every second.
                                    Power supply board:
                                    PS on 0v
                                    Stby 5v
                                    VS CON 1.72v
                                    VS ON 3.2v
                                    VS 208v
                                    VA. 57v
                                    X buffer :
                                    Svt vs 209v
                                    Svt xout>flactuating between 280 to 900v
                                    Y main board:
                                    Svt vs. 208v
                                    Svt ve. more than 1000v
                                    Svt yg c More than 1000v
                                    Svt yout flactuating between 400v and 1900v
                                    Svt...
                                    11-24-2023, 09:26 AM
                                  • KYBOSH
                                    Samsung UN55MU8000 - Backlight But No Picture Problem
                                    by KYBOSH
                                    Hello all
                                    I pick this up free as a repair project for the holidays.
                                    The original symptom was power cycling after 3-4 seconds with a single red light flash.
                                    To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                                    I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                                    12-21-2022, 12:42 AM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
