Issue with Samsung UE32D5520 turning on and off
    • 12087
    • U.S.
    Re: Issue with Samsung UE32D5520 turning on and off
    If you sort it out turn OFF auto updates because there's something fishy about a LOT of samsung updates screwing tv's up, big time.
    • Diah
      • Feb 2013
      • 6354
      reset TV from the access menu useless to repair / over write bad sectors on NAND
      Only Hard reset from service menu will do the job.
        • 12087
        • U.S.
        Maybe diff can hook you up with that 20 Pound nand chip, took a quick look only saw one for 33.
          • 12087
          • U.S.
          I think he already reset it Diah.
          • DiamondHands
            • Feb 2021
            • 10
            • Ireland
            Thanks all, yes I did the factory reset from the service menu as some of D series Samsung's have no option to reset within the normal menu.
            I'll try renaming the file and if that doesn't work then it looks like I'll just buy a pre-programmed Nand unless anyone has any further suggestions?
            Thanks for all the help by the way.
            • Russ17
              • Mar 2018
              • 125
              I have the same issue on a D series. What was the outcome? Did you replace the NAND chip?
              Regards
              Russ
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • C152Heavy
                by C152Heavy
                Summary for TL-DR readers:
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • alltvrepairs
                Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                by alltvrepairs
                I have confirmed that I have a mainboard problem.
                I have tracked no hardware issued on board so might be a software dump required.
                I have searched a bit but wasn't able to find anything for my screen:
                Here are some more details:
                Panel: cy-nn065hgev1h
                Main: BN94-14180M P08F
                Your help much appreciated!
                05-16-2025, 03:03 AM
                09-07-2024, 05:50 AM
