Issue with Samsung UE32D5520 turning on and off
  • nomoresonys
    • 12331
    • U.S.
    Re: Issue with Samsung UE32D5520 turning on and off
    If you sort it out turn OFF auto updates because there's something fishy about a LOT of samsung updates screwing tv's up, big time.
    • Diah
      • Feb 2013
      • 6599
      reset TV from the access menu useless to repair / over write bad sectors on NAND
      Only Hard reset from service menu will do the job.
      • nomoresonys
        • 12331
        • U.S.
        Maybe diff can hook you up with that 20 Pound nand chip, took a quick look only saw one for 33.
        • nomoresonys
          • 12331
          • U.S.
          I think he already reset it Diah.
          • DiamondHands
            • Feb 2021
            • 10
            • Ireland
            Thanks all, yes I did the factory reset from the service menu as some of D series Samsung's have no option to reset within the normal menu.
            I'll try renaming the file and if that doesn't work then it looks like I'll just buy a pre-programmed Nand unless anyone has any further suggestions?
            Thanks for all the help by the way.
            • Russ17
              • Mar 2018
              • 125
              I have the same issue on a D series. What was the outcome? Did you replace the NAND chip?
              Regards
              Russ
              • Cooperr
                Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                by Cooperr
                I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                10-21-2025, 01:11 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • Kjell
                Samsung Series 9 - BIOS issue
                by Kjell
                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                08-01-2025, 09:15 AM
