Philips QFU1.1 Kernel Panic
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    Typical issues of a QFU chassis: doesn't start sometimes, sometimes nothing after some hours etc.
    When not starting, this thing gives a Kernel panic when logging.
    So first things first: reballing of the Fusion, same behavior. Tried a NAND from a working SSB from exactly the same tv (40PFL8007K/12), the same Kernel panic.
    I know too little from a Linux system to interpret this error. Could a Linux professional give me some help pls.
    When I log the working SSB, I've got exactly the same till the Kernel Panic.
    Please find the log in attached PDF.
  • Diah
    • Feb 2013
    • 6363
    Re: Philips QFU1.1 Kernel Panic
    swap NAND will bring nothings to you because each boards had its owned security Keys generated at update, any panic log dont think its firmware or Kernel.... so the main fault remain the Fusion CPU. how much you sure on yours reballing work.. still the PCB sandwich invisible to you.. so it was always advised after removing the chip we exam the resistances of the soldering joint under the chip before placing the chip again.
    • Maalobs
      • Jun 2016
      • 120
      • Sweden
      If you search for "error" and step through all the hits, you'll find these two:
      Code:
      Reading out data:
      04 unit:
      waiting ECC result ready
      01 bits error in the unit.
      CWord at 0x1C, Error Mask:0x2000000.
      Code:
      06 unit:
      CWord at 0x45, Error Mask:0x100.
      ECC error sounds like bad RAM, and from the location in the log output (preceding U-Boot starting and reading the NAND) it appears that it is RAM-testing.
      This might be the cause of your troubles.
      I was expecting there to be an error code for bad RAM detected during POST which would throw the TV into protection mode, but when inspecting the error code overview in table 5-2 in the service manual, apparently there is no code for this error.
      That would explain why you get random kernel panics after the system has been booted on RAM with bit errors.
      If you also search for "warn" in the log output, you'll find this line:
      Code:
      UBI warning: ubi_eba_init_scan: cannot reserve enough PEBs for bad
      PEB handling, reserved 4, need 40
      It's surrounded by a great many "fixable bit-flip detected", soft errors in NAND consistency, before and after that line.
      I think the warning is telling you that the Bad Block Table of the NAND has already been maxed out and no more bad blocks can be mapped away.
      The 0x2C38 Device ID indicates that it's a Micron MT29F8G08ABABA 1 Gbyte NAND.
      They have been out of production for long time now, but if you search on AliExpress, maybe you can still find someone selling them in a "slightly used" condition.
      On the very last line you have this:
      Code:
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(249,0)
      Is the filesystem mount failing because of a too badly damaged NAND or by bad RAM, I honestly can't tell.
      PS:
      It's completely reasonable to attach log textfiles as txt-files in the future.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4318
        • Italy - Milan
        From what i know the most possibile answer of theese behaviours is that reballing is not come well, in other cases even if reballing is ok since theese are smart tv so them saves data on to flash rom, with the previous state of the cpu, data loss could happen and have ruined sectors content, so a FS fixing or software rewriting is neccessary.
        • Wiebotje
          • Jan 2021
          • 9
          • Belgium
          I talked to Beeldbuisje on Circuitsonline.net and asked to check the reference voltages of 750mV for the DRAM's. He came to the conclusion that one of the resistor chips was broken. Replaced and tv was repaired.
          • sofles
            Macbook Pro 16" A2141 screen artefacts, kernel panic
            by sofles
            Hi there.
            I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
            I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
            Now situation looks like this, If...
            02-05-2025, 05:05 AM
          • prw07
            MacBook Pro A2141 - macOS Kernel Panic
            by prw07
            Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
            How to localize the problem ?
            12-05-2023, 06:57 AM
          • ronaldopdias
            A1990 Constant Kernel Panic: AMDFramebufferVIB::setPowerState
            by ronaldopdias
            Hi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
            Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura....
            07-07-2023, 01:58 AM
          • Wachenaggo
            Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
            by Wachenaggo
            I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
            Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
            I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
            I also manage to damage...
            03-29-2022, 07:36 AM
          • Daniel Kubica
            Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
            by Daniel Kubica
            I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
            I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
            06-14-2025, 09:24 AM
