Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
  • Wachenaggo
    • Jul 2018
    • 66
    • Philippines
    I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
    Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
    I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
    I also manage to damage the chip because of repeated heat. Didn't have jtag connector. 😢
    I am completely lost or I am doing something wrong or this is a waste of time.
    Maybe some of you encounter this issue and resolved it. Thank you.
    Here is the Kernel Panic message below
  • reformatt
    • Feb 2020
    • 1528
    Re: Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
    You start with physical examination of the board for any signs of liquid damage and/or corrosion. If there is crap under a BGA (CPU/PCH/SMC etc), this can cause strange behaviour of some boards. Sometimes ultrasonic cleaning can solve some of these issues. But this is only done after you've identified all areas of corrosion and dealt with them. No point doing this straight up as it washes away all the evidence.
    Get yourself a half decent programmer (RT809 is pretty cheap) and flip top style adaptor for EEPROM programming. You can get replacement EEPROM's off Ali or take it off a donor board.
    https://www.aliexpress.com/item/1005003407813371.html
    • Wachenaggo
      • Jul 2018
      • 66
      • Philippines
      Thank you for the reply I solve it. by reballing SMC.
      • sofles
        Macbook Pro 16" A2141 screen artefacts, kernel panic
        by sofles
        Hi there.
        I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
        I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
        Now situation looks like this, If...
        02-05-2025, 05:05 AM
      • kurtspirit
        Macbook Air A1466 2013 reboot and kernel panic
        by kurtspirit
        I currently have a Macbook Air A1466 which has constant reboots or kernel panics without ever wanting to start.
        If I boot from a USB installation drive, everything is fine but when I run a new system installation on a new drive or external drive, it freezes after a while. I was able to detect a small artifact on the screen during the freeze but I'm not sure if it's specific.
        I measured some voltages on the motherboard and I could see that the 1.8V fell to 0V during the reboot but maybe this is normal? The other voltages (5V, 3V, 16V if I'm not mistaken) are ok and...
        06-30-2022, 02:15 AM
      • prw07
        MacBook Pro A2141 - macOS Kernel Panic
        by prw07
        Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
        How to localize the problem ?
        12-05-2023, 06:57 AM
      • ronaldopdias
        A1990 Constant Kernel Panic: AMDFramebufferVIB::setPowerState
        by ronaldopdias
        Hi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
        Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura....
        07-07-2023, 01:58 AM
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
