A1990 Constant Kernel Panic: AMDFramebufferVIB::setPowerState
  • ronaldopdias
    • Jul 2015
    • 93
    • United Kingdon
    Hi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
    Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura.
    panic(cpu 0 caller 0xffffff801f6fb928): AMDFramebufferVIB::setPowerState(0xffffff9055643800 : 0xffffff7fb488a8ee, 0 -> 1) timed out after 45641 ms @IOServicePM.cpp:5604
    Panicked task 0xffffff8b88589bf8: 247 threads: pid 0: kernel_task
    Backtrace (CPU 0), panicked thread: 0xffffff951ececb30, Frame : Return Address
    0xffffffc88cc63a70 : 0xffffff801f06e4fd
    0xffffffc88cc63ac0 : 0xffffff801f1c30a4
    0xffffffc88cc63b00 : 0xffffff801f1b2b29
    0xffffffc88cc63b60 : 0xffffff801f00e951
    0xffffffc88cc63b80 : 0xffffff801f06e7dd
    0xffffffc88cc63c70 : 0xffffff801f06de87
    0xffffffc88cc63cd0 : 0xffffff801f7dc34b
    0xffffffc88cc63dc0 : 0xffffff801f6fb928
    0xffffffc88cc63e30 : 0xffffff801f6fb2b9
    0xffffffc88cc63e40 : 0xffffff801f71504e
    0xffffffc88cc63e80 : 0xffffff801f6f9fd8
    0xffffffc88cc63ea0 : 0xffffff801f0c4958
    0xffffffc88cc63ee0 : 0xffffff801f0c5a08
    0xffffffc88cc63fa0 : 0xffffff801f00e19e
    Process name corresponding to current thread (0xffffff951ececb30): kernel_task
    Mac OS version:
    22F82
    Kernel version:
    Darwin Kernel Version 22.5.0: Thu Jun 8 22:22:22 PDT 2023; root:xnu-8796.121.3~7/RELEASE_X86_64
    Kernel UUID: B82210B0-6371-3C15-8D2B-47C6E1FB7879
    roots installed: 0
    KernelCache slide: 0x000000001ec00000
    KernelCache base: 0xffffff801ee00000
    Kernel slide: 0x000000001ecdc000
    Kernel text base: 0xffffff801eedc000
    __HIB text base: 0xffffff801ed00000
    System model name: MacBookPro15,1 (Mac-937A206F2EE63C01)
    System shutdown begun: NO
    Hibernation exit count: 0
    System uptime in nanoseconds: 217144541808
    Last Sleep: absolute base_tsc base_nano
    Uptime : 0x000000328ed2d12a
    Sleep : 0x0000002796d15253 0x00000000583d1310 0x000000255f4346c4
    Wake : 0x00000027a666c264 0x0000000058cf057a 0x00000027a1a3e46e
    Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
    Zone info:
    Zone map: 0xffffff8052983000 - 0xffffffa052983000
    . PGZ : 0xffffff8052983000 - 0xffffff8056984000
    . VM : 0xffffff8056984000 - 0xffffff8522cb7000
    . RO : 0xffffff8522cb7000 - 0xffffff86bc31d000
    . GEN0 : 0xffffff86bc31d000 - 0xffffff8b88650000
    . GEN1 : 0xffffff8b88650000 - 0xffffff9054983000
    . GEN2 : 0xffffff9054983000 - 0xffffff9520cb6000
    . GEN3 : 0xffffff9520cb6000 - 0xffffff99ecfe9000
    . DATA : 0xffffff99ecfe9000 - 0xffffffa052983000
    Metadata: 0xffffffccc0744000 - 0xffffffcce0744000
    Bitmaps : 0xffffffcce0744000 - 0xffffffcce6744000
    Extra : 0 - 0
    last started kext at 20856585632: |IOAVB!F 1140.6 (addr 0xffffff7fb465b000, size 81920)
    loaded kexts:
    >BCMWLANFirmware4388.Hashstore 1
    >BCMWLANFirmware4387.Hashstore 1
    >BCMWLANFirmware4378.Hashstore 1
    >BCMWLANFirmware4377.Hashstore 1
    >BCMWLANFirmware4364.Hashstore 1
    >BCMWLANFirmware4355.Hashstore 1
    >X86PlatformShim 1.0.0
    >!APlatformEnabler 2.7.0d0
    >AGPM 131
    @filesystems.autofs 3.0
    >!AHIDALSService 1
    >!ATopCaseHIDEventDriver 6440.7
    @kext.AMDFramebuffer 4.1.2
    >!AUpstreamUserClient 3.6.9
    @kext.AMDRadeonX4000 4.1.2
    @kext.AMDRadeonServiceManager 4.1.2
    >!AGFXHDA 240.1
    >!ABridgeAudio!C 340.1
    >!AGraphicsDevicePolicy 7.1.18
    >!A!IKBLGraphics 20.0.6
    @AGDCPluginDisplayMetrics 7.1.18
    >pmtelemetry 1
    @filesystems.nfs 1
    |IOUserEthernet 1.0.1
    >usb.!UUserHCI 1
    >!AHV 1
    >!ADiskImages2 198.100.13
    >!AMuxControl2 7.1.18
    @kext.AMD9500!C 4.1.2
    >AGDCBacklightControl 7.1.18
    >!ABacklight 180.8
    >!AMCCSControl 1.16
    @UVCService 1
    >!A!ISlowAdaptiveClocking 4.0.0
    >!A!ICFLGraphicsFramebuffer 20.0.6
    >!AFIVRDriver 4.1.0
    >!A!IPCHPMC 2.0.1
    >!AThunderboltIP 4.0.3
    >ACPI_SMC_PlatformPlugin 1.0.0
    >BridgeAudioCommunication 340.1
    >!AAVEBridge 6.1
    >!AFileSystemDriver 3.0.1
    @filesystems.tmpfs 1
    @filesystems.lifs 1
    @filesystems.hfs.kext 627.100.6
    @BootCache 40
    @!AFSCompression.!AFSCompressionTypeZlib 1.0.0
    @!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
    @filesystems.apfs 2142.120.7
    >!ABCMWLANBusInterfacePCIeMac 1
    @private.KextAudit 1.0
    >!ASmartBatteryManager 161.0.0
    >!AACPIButtons 6.1
    >!ASMBIOS 2.1
    >!AACPIEC 6.1
    >!AAPIC 1.7
    $!AUserConsent 1
    @!ASystemPolicy 2.0.0
    @nke.applicationfirewall 403
    |IOKitRegistryCompatibility 1
    |EndpointSecurity 1
    @Dont_Steal_Mac_OS_X 7.0.0
    @kec.Compression 1
    @kec.!AEncryptedArchive 1
    |IOAVB!F 1140.6
    @plugin.IOgPTPPlugin 1150.2
    >!AActuatorDriver 6440.7
    >!AHIDKeyboard 231
    >!AMultitouchDriver 6440.7
    >!AInputDeviceSupport 6440.8
    >!AHS!BDriver 6440.7
    >IO!BHIDDriver 9.0.0
    @kext.AMDRadeonX4100HWLibs 1.0
    >!UAudio 540.8
    >!AAudioClockLibs 240.1
    @kext.AMDRadeonX4000HWServices 4.1.2
    >!AHDA!C 440.2
    |IOHDA!F 440.2
    |IOAudio!F 440.2
    @vecLib.kext 1.2.0
    >!A!ILpssUARTv1 3.0.60
    >!A!ILpssUARTCommon 3.0.60
    >!AOnboardSerial 1.0
    >!ASMBusPCI 1.0.14d1
    @kext.triggers 1.0
    >IOHIDPowerSource 1
    >!ACallbackPowerSource 1
    |IO!BSerialManager 9.0.0
    |IO!BPacketLogger 9.0.0
    |IO!BHost!CUSBTransport 9.0.0
    |IO!BHost!CUARTTransport 9.0.0
    |IO!BHost!CTransport 9.0.0
    >IO!BHost!CPCIeTransport 9.0.0
    |CSR!BHost!CUSBTransport 9.0.0
    |Broadcom!BHost!CUSBTransport 9.0.0
    |Broadcom!B20703USBTransport 9.0.0
    >!ARSMChannel 1
    |IORSM!F 1
    >!AIPAppender 1.0
    >!AGraphicsControl 7.1.18
    @kext.AMDSupport 4.1.2
    >!ABacklightExpert 1.1.0
    |IONDRVSupport 597
    >!ASMBus!C 1.0.18d1
    @!AGPUWrangler 7.1.18
    |IOSlowAdaptiveClocking!F 1.0.0
    |IOAccelerator!F2 475.40.6
    @!AGraphicsDeviceControl 7.1.18
    |IOGraphics!F 597
    >!AThunderboltEDMSink 5.0.3
    >!AThunderboltDPOutAdapter 8.5.1
    >IOPlatformPluginLegacy 1.0.0
    >X86PlatformPlugin 1.0.0
    >IOPlatformPlugin!F 6.0.0d8
    >driverkit.serial 6.0.0
    >usb.IOUSBHostHIDDevice 1.2
    >usb.cdc.ecm 5.0.0
    >usb.cdc.ncm 5.0.0
    >usb.cdc 5.0.0
    >usb.networking 5.0.0
    >usb.!UHostCompositeDevice 1.2
    >!AThunderboltPCIDownAdapter 4.1.1
    >!AThunderboltDPInAdapter 8.5.1
    >!AThunderboltDPAdapter!F 8.5.1
    >!AHPM 3.4.4
    >!A!ILpssI2C!C 3.0.60
    >!A!ILpssI2C 3.0.60
    >!A!ILpssDmac 3.0.60
    >!ABSDKextStarter 3
    |IOSurface 336.50.1
    @filesystems.hfs.encodings.kext 1
    >!ASyntheticGame!C 10.6.3
    >!AXsanScheme 3
    >!AThunderboltNHI 7.2.81
    |IOThunderbolt!F 9.3.3
    >usb.!UVHCIBCE 1.2
    >usb.!UVHCICommonBCE 1.0
    >usb.!UVHCI 1.2
    >usb.!UVHCICommon 1.0
    >!AEffaceableNOR 1.0
    |IOBufferCopy!C 1.1.0
    |IOBufferCopyEngine!F 1
    |IONVMe!F 2.1.0
    >!ABCMWLANCoreMac 1.0.0
    |IO80211!F 1200.13.0
    >IOImageLoader 1.0.0
    >!AOLYHALMac 1
    |IOSerial!F 11
    >corecapture 1.0.4
    >usb.!UHostPacketFilter 1.0
    |IOUSB!F 900.4.2
    >usb.!UXHCIPCI 1.2
    >usb.!UXHCI 1.2
    >!AEFINVRAM 2.1
    >!AEFIRuntime 2.1
    >!ASMCRTC 1.0
    |IOSMBus!F 1.1
    |IOHID!F 2.0.0
    |IOTimeSync!F 1150.2
    |IOSkywalk!F 1.0
    >mDNSOffloadUserClient 1.0.1b8
    |IONetworking!F 3.4
    >DiskImages 493.0.0
    |IO!B!F 9.0.0
    |IOReport!F 47
    $quarantine 4
    $sandbox 300.0
    @kext.!AMatch 1.0.0d1
    >!ASSE 1.0
    >!AKeyStore 2
    >!UTDM 554
    |IOUSBMass!SDriver 235.100.2
    |IOSCSIBlockCommandsDevice 482.120.2
    |IO!S!F 2.1
    |IOSCSIArchitectureModel!F 482.120.2
    >!AFDEKeyStore 28.30
    >!AEffaceable!S 1.0
    >!ACyrus 1
    >!AMobileFileIntegrity 1.0.5
    $!AImage4 5.0.0
    @kext.CoreTrust 1
    >!ACredentialManager 1.0
    |CoreAnalytics!F 1
    >KernelRelayHost 1
    |IOUSBHost!F 1.2
    >!UHostMergeProperties 1.2
    >usb.!UCommon 1.0
    >!ABusPower!C 1.0
    >!ASEPManager 1.0.1
    >IOSlaveProcessor 1
    >!AACPIPlatform 6.1
    >!ASMC 3.1.9
    |IOPCI!F 2.9
    |IOACPI!F 1.4
    >watchdog 1
    @kec.pthread 1
    @kec.Libm 1
    @kec.corecrypto 12.0
  • Skruzo
    Hi. Did you find what was the problem?
    I have A1990 8210-0141 2.6I7 16Gb 1TB. Works perfect as long as it is on, restarts itself only in sleep mode.
    Tried everything - clean install, DFU, delate-clean install, nothing helped. No Hardware error code. Motherboard is completely clean, battery is good.
    It was my work horse from 2018 and still pretty good for my everyday tasks so I could use it for couple of more years..
    Any help will be appreciated
    • prw07
      MacBook Pro A2141 - macOS Kernel Panic
      by prw07
      Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
      How to localize the problem ?
      12-05-2023, 06:57 AM
    • sofles
      Macbook Pro 16" A2141 screen artefacts, kernel panic
      by sofles
      Hi there.
      I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
      I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
      Now situation looks like this, If...
      02-05-2025, 05:05 AM
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • Wachenaggo
      Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
      by Wachenaggo
      I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
      Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
      I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
      I also manage to damage...
      03-29-2022, 07:36 AM
    • Beeldbuisje
      Philips QFU1.1 Kernel Panic
      by Beeldbuisje
      Typical issues of a QFU chassis: doesn't start sometimes, sometimes nothing after some hours etc.
      When not starting, this thing gives a Kernel panic when logging.
      So first things first: reballing of the Fusion, same behavior. Tried a NAND from a working SSB from exactly the same tv (40PFL8007K/12), the same Kernel panic.
      I know too little from a Linux system to interpret this error. Could a Linux professional give me some help pls.
      When I log the working SSB, I've got exactly the same till the Kernel Panic.
      Please find the...
      02-23-2021, 03:53 AM
