Help diagnosing no backlight and no picture - Wasabi Mango
  • viewfindr
    • Feb 2019
    • 37
    Hi there, I have a rather interesting looking set of boards in this Wasabi Mango U400UHD TV (korean OEM), not much information available online.
    The components inside appear to be a mismatch of OEMs - the power board comes up as an RCA part? The TCON has Samsung logos on it, and there are no real identifiers on the mainboard, which I think is a generic part?
    Either way, I'm not getting any indication of life now, aside from the power LED changing colors and the startup chime. The shutoff chime seems to be gone, although the LED does change from blue to red when shutting down. I was able to get it working for a period of time previously by jiggling some cables (not sure which it was, it just magically started afterwards), but have no such luck now.
    I didn't find any obvious test points or things to check on these boards - any pointers for what I should try to diagnose?
    Re: Help diagnosing no backlight and no picture - Wasabi Mango
    1) Can you show us the whole back side of the TV showing all the boards so we can see how they are connected together?
    2) Remove the power supply board and see if there are pin labels for the connectors printed on the bottom side of the board.
    • viewfindr
      • Feb 2019
      • 37
      Photos attached below. Thanks for the pointer to look behind the board. I'm guessing my next step will be to test the 5V and 24V outs to see if they're high when the power is on?
      There's unfortunately this plastic backing piece which is attached with pins that's rather hard to remove from the power board.
      • viewfindr
        • Feb 2019
        • 37
        Just took some measurements on the PSU - 5VSB line was about 5V with tv off, and measured 12.97V on the +12V line and 5.5V on the +5V line both on the bottom section and top section cables when powered up. Doesn't look like 24V pins are hooked up.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          There's also two other signal lines which look like PON and BK/ON for which the voltages have not been given
          • neilc6
            • Nov 2015
            • 1550
            Usually if a tv turns on and off with no backlight or a flash of backlight, the backlights are suspect. A LED tester is helpful in this scenario. Also confirm the backlight on control signal is going high.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              What's happened to the solder joint of the component above D22 as in your photo 2 - 2 in post #3
                Originally posted by dick_barton
                there's also two other signal lines which look like pon and bk/on for which the voltages have not been given
                +1
                • viewfindr
                  • Feb 2019
                  • 37
                  Sharp eyes! I think it's just a bit of debris - I was able to remove most of it with tweezers.
                  Here are the rest of the readings:
                  PS-ON: 3.1V
                  BK/ON: 5.1V
                  ADJ (I think, pin right above BK/ON): 4.7V
                  All of these measured about 20-50 mV when TV is powered off. Side note, I just noticed that the optical audio out port lights up when powered on, so it seems like unit is receiving adequate power?
                  • viewfindr
                    • Feb 2019
                    • 37
                    Any additional thoughts? Would it be possible to verify the backlight is working by shorting some of the pins on the psu directly?
                      • 12314
                      • U.S.
                      Can you post a clear picture of the label you mention on the back of the powerboard?
                      • viewfindr
                        • Feb 2019
                        • 37
                        There is no "label" per se, just a plastic shield behind the components on the back and where it's mounted against the metal back of the panel.
                        I've attached another angle of the back of the board, where it's more visible and the top pin outs are clearer. Is there anything else I should look out for?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Can you press menu on the remote and look very carefully with a bright light (torch) at an angle to see if there is an image on the screen.
                          I suspect you have bad led(s) or led connection
                          • viewfindr
                            • Feb 2019
                            • 37
                            I think you're right - I kept clicking around in the menus to see if it was visible, and started to see text at a very precise angle - very hard to find!
                            Miraculously, the TV suddenly lit up while I was doing this. It seems to be working as normal now, not really sure why - nothing was really changed during this time, and connections are the same. I noticed the back panel was a little warm, so could it have needed to warm up?
                            Still perplexed at why.. I checked pure white and black screens, and the lighting appears to be uniform as well.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              So it does appear to be some sort of backlight only issue. If you get it running again, turn the backlights down as far as you can while still having a visible image and see if this alters the sets behaviour.
                                • 12314
                                • U.S.
                                can you press menu on the remote and look very carefully with a bright light (torch) at an angle to see if there is an image on the screen.
                                +10
                                • viewfindr
                                  • Feb 2019
                                  • 37
                                  Yep, definitely the backlight. The set worked fine for about 5 power cycles, but now it's not lighting up again. Seems odd that it's temperamental, but I guess I'll have to take apart the panel and start testing the bulbs individually now.
                                    • 12314
                                    • U.S.
                                    Sounds like a loose connection in the back lights, most likely why it works only sometimes, lots of times a tap on the tv here and there (NOT ON THE SCREEN) will temporarily make the connection and it will work till it loses contact again.
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • Ierwin
                                      by Ierwin
                                      05-13-2025, 03:31 PM
                                    • groomit
                                      Philips 50PUS7363/12 Backlight but no picture
                                      by groomit
                                      I'm having trouble with above mentioned TV. Bought it defect.
                                      Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                      Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                      I can see backlight, but screen stays black.
                                      What I've tried:
                                      - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                      - Disconnect left side...
                                      11-22-2024, 02:43 PM
