LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
  • goldbird78
    • Feb 2018
    • 188
    • canada
    Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
  • Wilderone
    • May 2018
    • 76
    Re: LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
    Check for cold solder on the underside of the board, pretty common.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have a look at the components in this repair kit and check the parts on your power supply.
      http://tinyurl.com/1a2204s7
      • goldbird78
        • Feb 2018
        • 188
        • canada
        will check. Thx
        • goldbird78
          • Feb 2018
          • 188
          • canada
          Check all new parts and they match old, also checked with meter and all are good. Thx
          • goldbird78
            • Feb 2018
            • 188
            • canada
            This is a weird one, as mentioned below I checked and replaced the below components and put the the board back in and it did the exact same thing. As suggested I removed the board, reinspected and checked the complete board for cold solder joints and none were found. The board was a little dusty (I have seen much much worse) so I gave it a good dusting with a paint and tooth brush and put the board back in. Now the TV stays on now without issues, I have given it two tests for over 8 hours each. Is it possible there was some dust shorting out something on the board ??
            • huzo
              HP Omen shuts down when loading OS
              by huzo
              The model is 15ec-1061nm
              Board number is DAG3EDMB8D0​
              SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
              10-29-2024, 12:05 AM
            • brav1ez
              ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
              by brav1ez
              I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
              I’ve tried:
              - CMOS reset
              - Removing the SSD/HDD
              - Reseating RAM (removing each stick individually stops boot completely)
              - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
              With...
              09-07-2025, 10:47 AM
            • GRANDGG
              LG 42lw4500 flashing red light , wight light , 2 clicks
              by GRANDGG
              Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
              05-09-2025, 12:27 PM
            • chaos-theory
              Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
              by chaos-theory
              I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
              Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
              03-14-2025, 05:37 PM
            • baglaivlad
              A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
              by baglaivlad
              Hello everybody!
              Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
              After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
              11-20-2024, 08:14 AM
