LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
  • goldbird78
    • Feb 2018
    • 188
    • canada
    Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
  • Wilderone
    • May 2018
    • 76
    Re: LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
    Check for cold solder on the underside of the board, pretty common.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have a look at the components in this repair kit and check the parts on your power supply.
      http://tinyurl.com/1a2204s7
      • goldbird78
        • Feb 2018
        • 188
        • canada
        will check. Thx
        • goldbird78
          • Feb 2018
          • 188
          • canada
          Check all new parts and they match old, also checked with meter and all are good. Thx
          • goldbird78
            • Feb 2018
            • 188
            • canada
            This is a weird one, as mentioned below I checked and replaced the below components and put the the board back in and it did the exact same thing. As suggested I removed the board, reinspected and checked the complete board for cold solder joints and none were found. The board was a little dusty (I have seen much much worse) so I gave it a good dusting with a paint and tooth brush and put the board back in. Now the TV stays on now without issues, I have given it two tests for over 8 hours each. Is it possible there was some dust shorting out something on the board ??
            • huzo
              HP Omen shuts down when loading OS
              by huzo
              The model is 15ec-1061nm
              Board number is DAG3EDMB8D0​
              SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
              10-29-2024, 12:05 AM
            • Giggle2562
              Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
              by Giggle2562
              I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
              The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
              Here's what I've tried so far:
              • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
              • The laptop shows an image on the internal display for a few seconds before it shuts down.
              • I tried swapping the LCD panel with a known good one.
              • I tried swapping the LCD cable
              11-06-2025, 12:36 PM
            • riko 656
              Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
              by riko 656
              I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
              Laptop Model:
              • Model: Lenovo Legion Slim 5 16APH8
              • GPU: NVIDIA GeForce RTX 4070
              • Main BIOS chip size: 32MB
              • VBIOS chip size: 16MB
              Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
              What I Have Tried So Far:
              1. I
              11-04-2025, 05:14 AM
            • brav1ez
              ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
              by brav1ez
              I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
              I’ve tried:
              - CMOS reset
              - Removing the SSD/HDD
              - Reseating RAM (removing each stick individually stops boot completely)
              - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
              With...
              09-07-2025, 10:47 AM
            • GRANDGG
              LG 42lw4500 flashing red light , wight light , 2 clicks
              by GRANDGG
              Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
              05-09-2025, 12:27 PM
