Samsung Plasma power supply, blown standby IC
  • PowerAmpFreak
    • 982
    • Sweden
    #41
    Re: Samsung Plasma power supply, blown standby IC
    Do you know WHAT is wrong with T3S? Is the primary open circuit?
    • trosdepep
      • Jul 2012
      • 70
      • Spain
      #42
      In the service manual you can see the T3S. All coils are continuous except for pins 1 and 2 of primary.
      • PowerAmpFreak
        • 982
        • Sweden
        #43
        If you're familiar with transformers you might check how the primary is wound, try to let some of the tape off and check if the primary is visible. Eventually, the primary is split in two windings, then it will be harder to repair it. If you're lucky you can see where the primary has shot off and again if you're lucky, eventually solder the wires back.
        If you're unlucky, the primary is wound as the layer closest to the core and you have to wind off all the secondaries which will be a hard work unfortunately.
        This is really nothing for the unexperienced.
        • trosdepep
          • Jul 2012
          • 70
          • Spain
          #44
          PowerAmpFreak many thanks for your advice. I was lucky and was on the outside coil. I've been able to weld easily. Now mark 0.5 ohms YUHUUUU!!!!
          Well, now I have to make the order of the break components:
          F9,R2, IC2, C268, C51
          I think these also will change in case:
          C37, C38, C50 they are around of the explosion
          I think they came in 1week.
          I'll keep you informed of my fight
          Thanks a lot.
          Regards.
          Pepe.
          • trosdepep
            • Jul 2012
            • 70
            • Spain
            #45
            I have put new components:
            F9, R2 (0.69ohm, original is 0,5ohms), Ic2, C268, C51 and C100.
            No works!!! and boooommm!!! C100 explodes!! Nooooo! its wrong polarity!!
            I put another new one right polarity. No works, no explosions. There is 235V on C100, no volts on transformer, pin7 of Ic2 marks 9,10, 11, 12, 9, 10 ,11....volts
            I check the area again, zd900 is shorted!!. (I think that is 8,8V zener)
            I extract de diode and and plug again, but now begins to smell of burning. Unplug quickly Ic2 is very hot.
            Tomorrow I will put new components, all caps (C37, C38, C50 too) ZD900 (8,8V) and ic2 and will try....
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #46
              You might want to consider making one of these instead of burning parts out.
              http://antiqueradio.org/dimbulb.htm
              • trosdepep
                • Jul 2012
                • 70
                • Spain
                #47
                I'm back to change all these components:
                C50, C51, C36, C37, C38, C46, C268, IC2 and ZD900 (8,2V zener) (I dont know why it is not in the diagram), R2 is ok (0,69 ohms)
                I have connected the tv with a 15w bulb in series. The bulb lights.
                Now I try with a 40w bulb. First lights and a pair of second begins to fade gradually, then I disconnect quickly and IC2 is hot, no a lot, but i think that if I don´t disconnect it burns.
                What happen? Is R2 0,69ohms right value, original is 0,5 ohms?... Is possible transformer not right?: I've fixed welding a transformer coil, but do not know the correct value, now marks 0.0 ohms (pins 1,2), pins 3,4 0.3 ohms, pins 5,6 1.5 ohms and secondary pins 10,7 0.0 ohms,
                I´m lost... I think problem is transformer...
                PS: When I was repairing the transformer broke the part that looks yellow in the pic below but I stuck with loctite...
                  If you cracked the core, the transformer needs to be replaced.
                  • trosdepep
                    • Jul 2012
                    • 70
                    • Spain
                    #49
                    I have been researching on the subject and what is broke is the ferrite core.
                    Some say that sticking is enough but others say no, and if it sticks, it quickly degrades and destroys.
                    Anyway I'm not sure that the circuit is ok with a new transformer ....
                    I think this ends my adventure. Next time take more care with the ferrite cores.
                    Thank you very much for your advice.
                    See you at the next repair.
                    Regards.
                    Pepe.
                    • raffaelecont
                      • Mar 2017
                      • italia
                      #50
                      salve sono nuovo di questo forum ho un grandissimo problema al plasma in questione mi è saltato i componenti IC2, R2, C268, C51 cambiati risaltano il problema è sul negativo ic2 salta il piedino 5 aiutooooooo
                      • raffaelecont
                        • Mar 2017
                        • italia
                        #51
                        salve ho risolto il problema dell ic2 ora ho 18volt ovunque suggerimenti?grazie
                        • cheeky2
                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                          by cheeky2
                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                          06-15-2025, 05:12 AM
                        • alltvrepairs
                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                          by alltvrepairs
                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                          Any one met this problem in the past?...
                          10-08-2025, 07:34 AM
                        • lp20th
                          Samsung Plasma TV Power Supply Issue
                          by lp20th
                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                          11-28-2023, 10:28 AM
                          09-07-2024, 05:50 AM
                          03-31-2024, 02:12 PM
