Samsung PN50A550 Plamsa Vertical and Horizontal lines
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey everyone,
    I have a Samsung PN50A550 plasma with a bunch of vertical lines and a couple black horizontal lines/bars.
    I set the TV up to run the test pattern and all of the lines are still there. The TV also power cycles. It will show the white, red, and green patterns and then powers off and back on shortly after showing the blue pattern.
    I doubt all of the panel drivers and a few buffer ICs would've gone bad all at once, so that leaves the logic board.
    Can anyone verify my diagnosis? I would hate to buy a logic board and have it not be the problem.
    Also, the only logic boards I can find online have the same part number, but a different board number and revision number. Will this cause me any problems or will it still work fine.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: Samsung PN50A550 Plamsa Vertical and Horizontal lines
    Bump
    canadaboy25
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      I guess the next question is, does anyone know where I can even buy this board? The only one listed on ebay has the LVDS connector mounted in the right angle position instead of the vertical position so I would not be able to use it anyways.
      I'm not sure what part of the board causes this problem. Bad solder joints on the BGA chip?
      canadaboy25
      • R_J
        • 9588
        I just got rid of a PN50A450P that had 6 black lines near the top and the problem was the panel itself, but the picture was fine other than the lines.
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          How do horizontal lines indicate a panel failure? Doesn't that usually indicate a buffer board problem? What part of the plasma panel actually fails to give horizontal lines? I know the COF chips on the panel flex cables can cause vertical lines when they fail but the horizontal connections don't have these chips.
          It seems strange to me that it would be a panel failure as it all happened at once. The only common link between the vertical and horizontal lines would be the logic board wouldn't it?
          canadaboy25
          • R_J
            • 9588
            I scoped the buffer outputs and there was signal going to the panel on all the blank lines, This panel originally only had 2 black lines and over time it became 6 (I tried a different buffer board just to be sure) I had seen this before, I suspect the internal connection between the foil and internal element breaks . But maybe yours is different.
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              Hmm, that's a shame. I probed the ribbon cable going to the x driver boards from the logic board and a couple of the lines has no LVDS signals on them. I think that is what is causing the vertical lines but I can't be sure.
              canadaboy25
              • steveh_131
                • Nov 2013
                • 33
                Did you ever solve this? I have the same issue.
                • canadaboy25
                  What is normal?
                  • May 2013
                  • 509
                  No, I haven't. I am building a logic analyzer to record the LVDS signals going to and coming from the logic board to try and decipher the signal format they are using and see if the logic board is at fault.
                  I will post an update if I find anything out.
                  canadaboy25
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • noisykid
                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                    by noisykid
                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                    12-30-2024, 07:15 PM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • oxi1158
                    Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                    by oxi1158
                    My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                    I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                    10-09-2020, 08:37 PM
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
