Sony OLED XBR65A8G no video, PSU problem?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4301
    • Italy - Milan
    #101
    SVDD is Source voltage, the same as AVDD in many lcd tcon.. is around 15-17v
    check again the 2 caps by disconnecting first the ribbon cables, some high capacity gives zero ohm at first touch of dmm
    this discussion is nearly a trashcan, too much people possessing the same thread, also one with different issue.. i hate see this.. anyway my opinion is that most of the probabilities in all these oled discussions, is that there is a bad tcon, oleds are almost all from LG, LG has a.very.bad story of failing bga solder, i think this is a stereotype situation, the people gives the bad guy to a service shop, they say bad screen, they sells tcon as good, and all people are worry, i also suggested many times to get a tcon only if assured it comes from working tv / cracked panel.. i doubt people here undestand what i write.. bye..
    • thetomma
      • Oct 2024
      • 6
      • Poland
      #102
      Hello
      I've recently bought broken kd-65a8g with no image issue. Apart of that i bought used tcon ; -). Yesterday i saw this thread but did not start measuring boards yet. TV boots on older tcon, i can hear adnroid sounds, no image, no backlight. Green spots appeares on 0.5-1 second in left and/or right corners once i press power on remote. Oh the new TCON i got only 4 red diode blinks. Any suggestions?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4301
        • Italy - Milan
        #103
        This is a good interference useful for the thread, so this means one of two things, MB needs SW compatibility with TCON, i think is not so, or the two tcon are both damaged as they behaves differently, if you had read my last post you already has the answer on what to do (at least for me).. bye..
        • thetomma
          • Oct 2024
          • 6
          • Poland
          #104
          I think i got your point, i just saw your post and it was just the first idea, that i got broken tcon from the person who sold me as working, so both can be broken. Although it was mentioned in auction as tested. TCON's seems to be the same' i'll check all details once i got home ie serial numbers etc,
          • cheebster
            • May 2008
            • 372
            #105
            From what i've tested tcon that isn't calibrated will still display a picture but not optimal on the lg oled panels, from my experience. So i've removed these caps and the line is still shorted. Guess that one is going to recycling.. Sad
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4301
              • Italy - Milan
              #106
              you have to check to wich supply line those caps are connected to, i guess is SVDD, in that case the short is most probably in another hide cap, not on the cofs
              • cheebster
                • May 2008
                • 372
                #107
                Ok. So might be an idea to cutout the panel's metal sheet at the bottom and reveal stuff under ? Or check with thermal camera/thermal injection on that line, see if i can see heat on the panel's metal sheet and cut more precisely where i see the heat ? Possible or not suggested ? This line is 12v/22v or so it seems ?
                • thetomma
                  • Oct 2024
                  • 6
                  • Poland
                  #108
                  with EVDD from power board to TCON disconnected - "new" TCON, it stops blinking 4 times and i hear the android sounds, once tv boot. Does it mean definitely panel is shorted and the whole TV can be put to thrash only? Apart of selling single parts
                  • thetomma
                    • Oct 2024
                    • 6
                    • Poland
                    #109
                    Also im not sure that is important, when everything is connected, apart one of two ribbons from main-board to tcon board, then tv tried to boot with sound, kinda strange
                    • Diah
                      • Feb 2013
                      • 6357
                      only the lower LVDS which transport the SOS fault at module to MB
                      you can read the print at pins of error_xxxxxxx
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4301
                        • Italy - Milan
                        #111
                        1) have you checked or not to witch line the shorted caps belongs to?
                        2) with this evdd disconnected have you checked the basis supply lines if are present or shut down? Are you able to find and check them?
                        3) you cannot inject svdd line alone from what i remember, this is dangerous for the cof, you need first to supply the vcc line, that is 3,3v i think
                        • thetomma
                          • Oct 2024
                          • 6
                          • Poland
                          #112
                          1. I checked i think all caps on tcon, none seems to be shorted, also fuses seems to be ok.
                          2. I havent checked power supply lines yet, you mean measure voltage on lines from power source board to tcon when tcon is connected to evdd and whe in disconnected?
                          3. Thanks for warning, by the way evdd is the same as svdd?
                          By the way on old tcon i found PCB in that area has a bit different color, it looks like it was high temperature there or some liquid: Click image for larger version
                          • thetomma
                            • Oct 2024
                            • 6
                            • Poland
                            #113
                            How to read it, by connecting jack->usb you mentioned in that post?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4301
                              • Italy - Milan
                              #114
                              point 1 and 2, you have not understood, but, you tcon model is different from the one of Cheebster, i think one of you must leave the thread, too much confusion here!
                              • cheebster
                                • May 2008
                                • 372
                                #115
                                Oh well, got some progress here, cutted the metal plate so i could see the caps just a bit lower where the 4 lvds cables go from tcon to the panel, and found a shorted cap! Removed it, and tv doesnt blink anymore but no display, but ive got a butchered lvds cable from main to tcon. Gonna order a cable and see if it fixes this one!
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4301
                                  • Italy - Milan
                                  #116
                                  don't forget the panel auto test method
                                  • lotas
                                    • Jan 2016
                                    • 4555
                                    • Russia
                                    #117
                                    This is not a simple T-CON (LG), and you can't just put it into standalone mode.​
                                    • Diah
                                      • Feb 2013
                                      • 6357
                                      put back yours original t-con if you didn't missed with it
                                      after that you do hard reset by pressing the joystick down then plug in wall remove only after changing front LED from white to green
                                      • cheebster
                                        • May 2008
                                        • 372
                                        #119
                                        Here is the method posted by diah here;
                                        If you got at first test EVDD Lower than 24V then drop down... and the VIN remain at 12V or also drops down ... then do the next
                                        Second Test: ( running the power boards and the panel as stand alone )
                                        1- disconnect the Main boards totally from Power boards and from the T-CON ( mean disconnect the socket coming from the power boards & disconnect the 2 LVDS between Main boards and T-CON .. unplug them from T-CON Side )
                                        2- Disconnect the T-CON from Power boards ( unplug 2 sockets VIN & EVDD )
                                        3. RUN POWER BOARDS as Stand alone ....
                                        make bridge with R value 100 to 1K Ohm ( if the STBY 3.3V you can do it direct with out R but need to be sure 100% of the pins label )
                                        A- STBY & Power_ON ( this will turn on REG12V ON )
                                        B- STBY & TCON_12_ON ( this will turn on TCON_12V ON )
                                        C- STBY & EVDD_ON ( this will turn on EVDD V On Max 24V )
                                        if you confirmed all 3 Voltage in A,B,C you have ... then complete
                                        4- RUN The panel Module as Stand alone
                                        A- Feed the T-CON with VIN & EVDD V which you got at above points B & C
                                        Are you saying this wont work with these models ? All i get is a black screen with either original or replacement t-con, even with that panel test mode.
                                        I'm wondering if i should get a replacement set of cables. I attached 2 pictures, one is where i found a shorted cap, and second is the condition of the cable (can't even align it right it's so messed up, pins might not even be touching the socket pins properly.
                                        Also wondering, is the missing CAP (the one that was shorted) an issue ? They were all connected together, figured out missing one wasn't a big deal, maybe guess wrong.
                                        Rabbit hole!
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4301
                                          • Italy - Milan
                                          #120
                                          I think that EVDD must be fed lately, the separate switching is there for a reason, first power on and tcon 12v together, then after a couple seconds EVDD.. every lcd screen has a power sequence, surely oled are the same way, i think perfoming like the.other says is an high risk or is surely a disaster..
                                          ​​​​​​.. check again caps on the panel, your new attempt, maybe new disaster..
                                          • Spikeman
                                            Help on Video Problem on Dell Inspiron 7459
                                            by Spikeman
                                            Hi, I'll tell you the story of this PC.
                                            The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
                                            After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
                                            However, the PC later presented the problem in the video shared very frequently.
                                            The problem also occurs at startup, in the bios and when using it as a monitor thanks...
                                            02-27-2024, 10:17 AM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • zimeyh
                                            Problem video A1502
                                            by zimeyh
                                            Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
                                            11-15-2023, 03:19 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • hugocarmo
                                            Grundig GV-250 Repair problem. (Video inside post)
                                            by hugocarmo
                                            Hi everyone.
                                            I have the following problem.
                                            I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                            In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                            01-19-2023, 06:46 AM
