Grundig GV-250 Repair problem. (Video inside post)
  • hugocarmo
    • Feb 2021
    • 39
    • Portugal
    Hi everyone.
    I have the following problem.
    I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
    In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720, this on the upper part of the power supply board. On the soldering part, I replaced the bas20 switching diode.
    Always with the same result. I ended up disassembling the video head and removing the plate that is soldered to the motor, then I replaced all the electrolytics, and IC AN3814K. Same result.
    I don't know what to do anymore, can someone help me?
    I also enclose the Service Manual for this model.
    P.S.- At the end of the video, as you can see, the video recorder is working normally.
    Video Link:
    https://vimeo.com/790579424
    Service Manual Link:
    https://drive.google.com/file/d/17es...usp=share_link
    Thanks in advance,
    Compliments,
    Hugo do Carmo.
  • nomoresonys
    • 12306
    • U.S.
    Re: Grundig GV-250 Repair problem. (Video inside post)
    video not working for me, can you explain the issue or is it fixed?
    • hugocarmo
      • Feb 2021
      • 39
      • Portugal
      Hi nomoresonys.
      Thank You for your reply.
      I can try to upload the video to another platform but anyway, the issue is not fixed.
      When I connect the mains the vcr does nothing for a minute or so, then it starts to spin the head drum full speed for 2, 3 minutes and after that it starts to slow down until it stops, and after that the VFD turns on, it blinks and then the vcr starts to operate as normal.
      Thank You,
      Hugo.
      • hugocarmo
        • Feb 2021
        • 39
        • Portugal
        Here“s the Youtube video link.
        https://www.youtube.com/watch?v=UkrY4mZ1nJ4
        • R_J
          • Jun 2012
          • 9607
          Post the voltages on both plugs of the power supply. Also post pictures of both sides of the power supply so we can see what we are dealing with.
          The voltage of interest is the +12VF and the Reset
          • nomoresonys
            • 12306
            • U.S.
            vcr's are complicated, guess sometimes they can act funny if the sensors see too much light coming in, maybe try it while shielding the top with a big piece of cardboard or when the room is darker, may need to clean the mode switch, it seems like it isn't anything major, since you say it works ok after the 3+ minute spin of the head: This youtuber is very good with vcr's etc: https://www.youtube.com/watch?v=X2HXUaLe2vI
            • nomoresonys
              • 12306
              • U.S.
              wondering what the 23 means on display, could it be some kind of error code.
              • hugocarmo
                • Feb 2021
                • 39
                • Portugal
                Hi!!
                Just fixed the problem!
                It was a bad TDA4605, the one I replaced was new but not good, don“t know why.
                Replaced it and now everything working as expected.
                I want to thank You all for your answers.
                Best regards,
                Hugo.
                • nomoresonys
                  • 12306
                  • U.S.
                  Glad to hear it. was wondering if maybe one of the components you switched out was bad, you switched out quite a few, how did you determine which one was bad?
                  • hugocarmo
                    • Feb 2021
                    • 39
                    • Portugal
                    Hi nomoreonys.
                    I figured out measuring voltages on tda output pins, and they were lower than expected as mencioned on the service manual.
                    Regards.
                    • nomoresonys
                      • 12306
                      • U.S.
                      thanks, nice puzzle solving.
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
                        GeForce RTX2080 Super Aero video gaming card issues help need
                        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                        05-07-2023, 08:12 AM
                      • Flaku_34
                        Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                        by Flaku_34
                        Introduction:
                        Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                        04-18-2024, 12:47 PM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                        HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                        This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                        09-06-2024, 06:20 AM
