Sony OLED XBR65A8G no video, PSU problem?
  • Diah
    • Feb 2013
    • 6424
    Originally posted by cheebster
    Hello, same (about the same, a8h) tv here, 4 blinks on bootup. Tried Diah's post #4 suggestion, both 12v and 22v are being supplied to the T-Con, however panel stays black, nothing displayed. Should i try another tcon for the heck of it ? I see many voltages on the tcon near memory etc being generated by the inputs. No signs of physical damage to the panel at all. Should i at least get something displayed on the screen when 12v/22v is being fed to the t-con ? Any test pattern ? Thanks.
    at yours case you need just disconnect the lower LVDS between Main boards and T-CON then turn on the tv see if the 4 blinks remain or the set will start with black screen... yours sign of working are the audio optic port on MB will lit red and remain on also you could heat sound.$ we will know the condition of the OLED module..
    this post we are cutting the error collection pins on T-CON to MB to let the set complete boot... you can see the print chart of the lower LVDS on T-CON remarked with error.....
    • cheebster
      • May 2008
      • 374
      #82
      Yep, tried that, optical led is on and the tv stays on without the 4 blinks, with black screen. But that doesn't confirm it's either the panel or the t-con, right ?
      I ordered a t-con since it's cheap. Would swapping the t-con normally work without swapping the EMMC (at least give an image) ? Or the emmc needs to be swapped over to the new board before anything gets displayed ? Thanks.
      • Diah
        • Feb 2013
        • 6424
        test with just the EVDD rail socket disconnected from PSU side and turn on.. check if you still have 4 blinks
        • cheebster
          • May 2008
          • 374
          #84
          Same 4 blinks with everything connected but no evdd
          • Diah
            • Feb 2013
            • 6424
            this indicated oled cells are not the reason....cross finger yours replacements t-con will solve the blinking
            • cheebster
              • May 2008
              • 374
              #86
              Ok, thats good news. Do i need to migrate data or swap over the emmc? Thanks.
              • Diah
                • Feb 2013
                • 6424
                first check no more blinking..
                • cheebster
                  • May 2008
                  • 374
                  #88
                  Okay will do. When a line of cell or anything is shorted on the panel itself, ive seen the quick fixes where people are 'taping' lines (seen this on lcd's) on samsung panels where there was failed COFS, but i always wondered it there was a way to more precisely pinpoint on which line the short is, so that you can either cut/isolate the fault and get a working picture minus one line or something similar. Also wondered if that technique was working with OLED in some way, haven't seen any reports of success with such issues on oleds like it did on lcd's.
                  • Diah
                    • Feb 2013
                    • 6424
                    OLED Panel also have COF.. and also some time need banding if there line appears on screen,,, but the way to access to the area not easy... need to cut the metal which cover the area... for example
Name:	oled banding.jpg
                    • cheebster
                      • May 2008
                      • 374
                      #90
                      Yes to access it, but even there it's not fixable if it's the cof, only the CAPS. But bypassing the failed portion using taping/cutting/masking the pins is always an option i guess
                      • cheebster
                        • May 2008
                        • 374
                        #91
                        Ok, replaced t-con and same 4 blinks. Could it be that the code is stored into some memory or no ? Anything else i can try ?
                        Update, it now blinks 6 times now sure what that could mean.
                        • Diah
                          • Feb 2013
                          • 6424
                          try capture boot log via TTL adapter
                          • cheebster
                            • May 2008
                            • 374
                            #93
                            Ok, i don't know how to do that
                            • cheebster
                              • May 2008
                              • 374
                              #94
                              Um, it seems that at the bottom of the TV, one of the 3.5MM ports say RS-232C/Remote. Would this https://www.amazon.ca/Green-utech-Ad...ps%2C88&sr=8-4 Work ?
                              • Diah
                                • Feb 2013
                                • 6424
                                expensive.. TTL adapter will be no more than 6USD..LOL
                                remove the heatsink of yours MB and upload clear focused photo of it
                                notice my answer could be delay as i am watching today soccer champion league lol
                                • cheebster
                                  • May 2008
                                  • 374
                                  #96
                                  Hello, so doing a bit of poking around on this one i've found 2 shorted caps on the small area of the exposed panel pcb. Here is shown on the pictures the 2 caps corresponding to pins 4-6 of the flex on the tcon side, which goes to Q6 on the T-CON. Dead short on these 2 ! They are the 2 largest caps so i guess they are bigger voltages lines powering the backlight or the cells, seems to be closer to evdd connector. What does that mean ? No clue, short inside of panel itself ? I could inject voltage on the lines after removing caps and see if house catches fire ?
                                  • cheebster
                                    • May 2008
                                    • 374
                                    #97
                                    Here is a better closeup picture of where these lines goes, to SVDD side of the Q6. What is SVDD ?
                                    • Diah
                                      • Feb 2013
                                      • 6424
ID:	3480153 they are related to EVDD
                                      on the panel buffer boards 4 ribbon disconnected compare with ribbon 1. if they are different behavior lift one side of the cup carefully and check one by one.... if the short remain mean inside the panel,
                                      • lotas
                                        • Jan 2016
                                        • 4708
                                        • Russia
                                        #99
                                        SVDD - supply voltage within 12 - 16v
                                        • Diah
                                          • Feb 2013
                                          • 6424
                                          doesn't matter the name all related to EVDD socket
                                          • Spikeman
                                            Help on Video Problem on Dell Inspiron 7459
                                            by Spikeman
                                            Hi, I'll tell you the story of this PC.
                                            The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
                                            After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
                                            However, the PC later presented the problem in the video shared very frequently.
                                            The problem also occurs at startup, in the bios and when using it as a monitor thanks...
                                            02-27-2024, 10:17 AM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • zimeyh
                                            Problem video A1502
                                            by zimeyh
                                            Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
                                            11-15-2023, 03:19 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • hugocarmo
                                            Grundig GV-250 Repair problem. (Video inside post)
                                            by hugocarmo
                                            Hi everyone.
                                            I have the following problem.
                                            I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                            In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                            01-19-2023, 06:46 AM
