Panasonic 37” LCD LED
  • Mmatt
    • Nov 2020
    • 17
    Picked up a Panasonic TC-L37D2 off the curb. When turned on it powers up and the backlights flash then it goes into shutdown mode with 10 blinks. If I unplug the white connector on the power board that goes into the back of the panel (picture provided) backlights light up bright for a few seconds then get dimmer, but the set stays on.
    If I leave the white connector unplugged and also unplug the small connector going to t-con board (picture provided) the backlights come on and stay bright.
    In both scenarios I get a picture with what appears to be some of the colors missing. Scenario 1 gives dimmer picture and scenario 2 gives brighter picture but both have missing colors.
    Any thoughts would be helpful. I am not versed enough to repair a board but can change a board if I know what the problem is. I can use a multimeter with some limitations.
    With the larger white connector plugged into the top of the power board, it always goes into shutdown mode with 10 blinks.
  • neilc6
    • Nov 2015
    • 1550
    Re: Panasonic 37” LCD LED
    I googled and found your service manual. They usually contain troubleshooting steps for the blink code.
    • Mmatt
      • Nov 2020
      • 17
      I found a service manual and did some testing with a multi tester. I found the white connector CN01 that I unplugged to keep the backlight on is not receiving correct voltage. Pins 1 and 12 are getting 172V. The remaining pins 3, 4, 5, 8, 9 and 10 should get 79v but are showing only 1.4v. When plugged in it causes a shutdown. Does this mean the inverter that powers the LEDs is bad?
      The manual also says 10 blinks points to ZWEI2 sos on t con board.
      • R_J
        • Jun 2012
        • 9627
        Pins 1 & 12 are the LED supply voltage, 172v is likely correct, the other pins are the led string return lines, I would check the return line voltage on each of the 6 strings (with the led's connected) as the tv is turned on (and before the protection cuts in) I suspect one of the lines will check different indicating an open led string.
          +1
          Check the return lines with ref to circuit ground.
          • Mmatt
            • Nov 2020
            • 17
            I checked all the pins on CN01 and CN02 when tv powered up and before shut down. Pins 1 & 13 on CN01 and pins 1 & 12 on CN02 were 174v. All others were 158v. I didn’t see one that gave a different reading. The manual says they should read 79v.
              Originally posted by Mmatt
              I checked all the pins on CN01 and CN02 when tv powered up and before shut down. Pins 1 & 13 on CN01 and pins 1 & 12 on CN02 were 174v. All others were 158v. I didn't see one that gave a different reading. The manual says they should read 79v.
              Are you testing the return lines using circuit Ground (chassis) as ref ground for the meter's Black probe as suggested?
              • Mmatt
                • Nov 2020
                • 17
                If you are asking if I'm grounding the black probe to the television chassis, yes I am.
                • Mmatt
                  • Nov 2020
                  • 17
                  The tech manual says pin 5 on A03 sends 3.2v to tv sub on. I am getting only 2.7v on pin 5 to tv sub on. Could that cause the tv to shut down when LEDs try to come on?
                  • Mmatt
                    • Nov 2020
                    • 17
                    After rechecking, the tv sub on at pin 5 is 2.3v
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      If your Relay_5VS is present at connector A03, Pin 3, then TV_Sub_On is OK
                      • Mmatt
                        • Nov 2020
                        • 17
                        Dick Barton, thanks for the reply. I will check pin 3 when I get home from work and post back around 4:30-5:00
                        • Mmatt
                          • Nov 2020
                          • 17
                          Sorry I didn’t post back earlier. Got sidetracked with car trouble. Pin 3 on A03 has 5.97v
                          • Mmatt
                            • Nov 2020
                            • 17
                            Here's an update now. This morning I noticed I left the tv on with the 10 blinks going all night. Now I have standby power only. No relay clicking on the power board and turning it on as before. It goes straight to shut down and blinks 10 times. I get 5.9v on pin 3 and 2.3v pin 5 on connector A03 on main board. I have 5.9v on pin 11 of connector CN03 of power board that looks like it should turn on DTV 12v but I'm getting 0v to pin 4 on CN03.
                            Before all this the power board was clicking and backlights flashed on then went into shut down. Has the power board failed?
                            • nomoresonys
                              • 12332
                              • U.S.
                              Maybe look over your solder joints with a sharp eye, give m a wiggle test, see if any are bad/cold, can google bad joint images if needed.
                              • FZG
                                Panasonic AG-1000B VHS player with bad picture quality
                                by FZG
                                Hello!
                                I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                Also, what mechanism is this?
                                Any feedback is appreciated!...
                                05-06-2024, 07:16 AM
                              • DXseekerMO
                                TCL 55US57 backlights, no picture.
                                by DXseekerMO
                                So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                Power Supply, main and T-CON board are working.
                                Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                Unhook FFC from left side...
                                09-18-2021, 03:56 PM
                              • Bazfletch3
                                Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                by Bazfletch3
                                Hi all
                                While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                From there I envisaged that the backlighting wasn't working, however...
                                01-08-2024, 10:18 PM
                              • sordids999
                                SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                by sordids999
                                Hi
                                Really stuck on this TV
                                I'm thinking it's a bad screen ?
                                Voltages all seems good
                                Tcon 12v ok
                                Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                even tried the tape trick still no luck
                                Thanks...
                                05-12-2025, 10:36 AM
                              • stinger
                                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                by stinger
                                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                04-17-2024, 03:06 PM
