SONY KDL 43w805c does not accept commands
  • Diah
    • Feb 2013
    • 6395
    Re: SONY KDL 43w805c does not accept commands
    yes... but this time packing the boards complete at the kitchen often ... with high temperature and dont use air flow function .... or if you have toaster... etc... maybe the the BGA at the sandwich ... who knows... so better we go with this method
    • Dobsuk
      • May 2020
      • 127
      • England
      #42
      Are you joking, mate? Do you want me to put the board in the toaster?
      • Diah
        • Feb 2013
        • 6395
        no joking.. i dont know what do you have at home to apply complete heat at once to the board..
        • Diah
          • Feb 2013
          • 6395
          i used always Korean infrared BBQ grill.. LOL
          • Dobsuk
            • May 2020
            • 127
            • England
            #45
            OK. I have got oven, toaster and frying pan. Which one to use I would suggest the pan ))
            • Dobsuk
              • May 2020
              • 127
              • England
              #46
              OK. How to proceed?
              • Diah
                • Feb 2013
                • 6395
                which equipment are you going to use ? always please show me so no mistake done.
                • Dobsuk
                  • May 2020
                  • 127
                  • England
                  #48
                  Lets go for the toaster? Or oven? Which will be more prospective?
                  • Diah
                    • Feb 2013
                    • 6395
                    if toaster.. then the following
                    1- prepare the main boards
                    A- cover all sockets ( plastic ) with Aluminum Foil.. be sure the foil didn't touch the sockets such scart... audio Optic Out. LAN, video & audio in plugs , CI decoder
                    2- Test the boards size at the toaster to locate best place you will put it inside on plate
                    3- turn on the toaster full temperature and wait until it reach high temperature as the plate too
                    4- place the boards on the plate and close the door for 10 minutes if the temperature are round 280 degree
                    5- turn off the toaster.. carefully open its door with out let the boards shocking or moved
                    6- wait until its cooling down than take it out..
                    good luck
                    • zens electronics
                      • Jan 2021
                      • 31
                      #50
                      Hi apologies for late reply .
                      Please don't cook the main CPU .
                      Far as i am aware , this set suffers with EMMC chip issue & yes the company i mention microtech , based in Bolton can sort it .
                      Regards Zen
                      • Diah
                        • Feb 2013
                        • 6395
                        Regards Zen
                        explain what emmc to do with notification and IR signal... dont make advertisement to company you mentioned 10 time over this forum since you are registered,
                        one things more i will pay you 1000 $ if you can remark the emmc you are talking on at his boards... the photo he upload too LOL... keep silent and learn.
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          #52
                          Thank you, Diah. I will try this tomorrow may be as i am tired now. I appreciate you help, mate.
                          And my toaster does not have door, mate. It is just 2-slice toaster.....
                          • Diah
                            • Feb 2013
                            • 6395
                            then dont use it,,, lol you are in joking now.. oven will be better
                            • Dobsuk
                              • May 2020
                              • 127
                              • England
                              #54
                              Regards Zen
                              Yeah i sent them email 2 days ago and the answer was:
                              Main emmc faulty we dona service for this model please be advised no netflix or amazon prime or chromecast apps are down please use fire stick which is 100%
                              Then my question was "How come without Netflix etc.." and they answered me:
                              Sorry if you want 100% working board please buy 1 on ebay to replace it we only repair the board with few apps that do not work that we advice and have plenty of our customers who take the service anyway good luck all the best
                              So, not much helpful....
                              • zen
                                • 511
                                #55
                                Sorry Diah , i'm just trying to help .
                                I won't mention any companies in future , that i believe can help resolve the issue .
                                The EMMC chip holds the full android operating system , and when data becomes corrupted , it can cause many different fault symptoms on TV .
                                • zen
                                  • 511
                                  #56
                                  Pictures of board are not clear , but the chip i mentioned is either the B G A type below the optical socket , or it may be under the white ceramic plate covering the CPU .
                                  • Diah
                                    • Feb 2013
                                    • 6395
                                    its okay..
                                    MT5830BPHJ are the brain of this set it control all function.. include the IR.. if one BGA POINT get OPEN this function will be error.. IR are function and here we have the case. who knows which POINT.. but we still can guess the side of the chip where the OPEN POINT are.
                                    actually if the OP had Air Mouse the procedure will be more easy after he pass first installation then activate the developer Option & USB Debug so we can with adb proof the IR function.
                                    • zen
                                      • 511
                                      #58
                                      Main CPU could potentially have poor ball connection issue , but it's just not something i have had on this specific model .
                                      • Diah
                                        • Feb 2013
                                        • 6395
                                        OP did many time hard reset.. it mean the NAND being erase and the Firmware again extracted and wrote back to the active partition of NAND. if there corrupted sector at chip for example it will not pass the erase. and if some one think the firmware corrupted , the firmware cashed on protected level. no access to any app or user to change or delete... beside it extracted correct after erase. the only things left the CPU.
                                        • zen
                                          • 511
                                          #60
                                          Thanks very much for the additional information .
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • Ruptor
                                            Sony MHC 6600 volume clicking
                                            by Ruptor
                                            Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                            05-21-2023, 05:32 AM
                                          • jason123
                                            Sony STR-DN1030 Distorted audio when Volume adjusted
                                            by jason123
                                            New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
                                            All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
                                            First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
                                            Second thought was the ribbon cable from front display to control board (V-Flex,...
                                            06-05-2022, 12:54 PM
