SONY KDL 43w805c does not accept commands
  • Dobsuk
    • May 2020
    • 127
    • England
    Hi, guys. This TV stopped to accept commands and it does not matter if i am using my remote control or the buttons on the TV. It is accepting it sometimes but only once or something and then it is stopping again. Only the volume command is working even i cannot see the graphic scale every time. But the volume is working - i can adjust the volume without problems. I reset the TV few times but it is the same. Now it stuck on the Welcome Screen and i cannot move forrward. Do you think that the Main Board could be a problem?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: SONY KDL 43w805c does not accept commands
    If you disconnect the wifi connector does that help. I think it's connected to the IR sensor module.?
    IR SENSOR WIFI MODULE SIDE CONTROL BUTTONS FOR 43" SONY BRAVIA KDL-43W805C TV
    • zen
      • 511
      Only one company i know in the UK that can repair main board .
      I believe they advertise service on E BAY .
      Company name is Micro tech .
      • Dobsuk
        • May 2020
        • 127
        • England
        Yeah i tried to disconnect each part one by one but nothing
        • Diah
          • Feb 2013
          • 6357
          its much firmware issue, as its android 5. there are update for years 2019 to this set- you need to try
          1- hard reset from power & volume - then plug it in wall socket..
          2- to by pass the first installation and to to apply update use air mouse with the tv. or any USB 2 mouse.
          • Dobsuk
            • May 2020
            • 127
            • England
            Are you talking about this one? I am looking to buy another one but it looks they are not very cheap.... Just wanted to make sure that this is the problem
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Possibly this one
              https://microtech-av-spares.com/
                • 12128
                • U.S.
                Did you try Diah's suggestion in post #5?
                • Dobsuk
                  • May 2020
                  • 127
                  • England
                  So, did hard reset few times but did not try with the mouse. Will try it now. The TV is with the last firmware downloaded from sony website.
                  • Diah
                    • Feb 2013
                    • 6357
                    with mouse you can setting the tv as u like... the Notification graphic scale should work again after the hard reset... because its can turned off via setting.
                    take the batteries out from your RC in case the RC keep sending IR signal.. then use the side control panel .. you can try android APK too if you have android mobile with IR sender such galaxy S5. i think sony they have apk too to control the set via net work too.
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      Yeah, but the point is it stuck on the welcome screen. So, i cannot use any APK to control it via the network until the tv is not connected to the network. And my problem is not that this volume graphic is missing... The problem is that it does not accept command neither from the remote control nor from the side control panel.
                      Just tried with the mouse now and nothing - i can see the mouse coursor and move it for 2-3 sec and then it is freezing for few sec and so on.... Is there how to reflash the TV with USB stick even it is with the latest firmware already?
                      • Diah
                        • Feb 2013
                        • 6357
                        f you did hard reset as press power and Volume - then plug set in AC and it show for you erase on screen .. then Air mouse will work.
                        put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed. if this not help need to open the cover and show me the main boards to see which version its.
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          YEah it is working but for few seconds only... then it is freezing for few secs and so on.
                          Did that about 10 times but nothing - it is just looping in the boot logo and turn off again and on and off ..... May be it is not possible to reflash it with the same firmware version. Found some procedure for downgrade on Internet but cannot find older firmware for my TV.
                          Thank you, Diah!
                          • Diah
                            • Feb 2013
                            • 6357
                            did you use air mouse??
                            Thank you, Diah!
                            there are 2 kind of regions android 5 for Sony 2015 as yours w805c so i listed for you very early version for eua ...
                            and this eua sony_tvupdate_2015_2637_eua_auth.zip
                            • Dobsuk
                              • May 2020
                              • 127
                              • England
                              Errm, no mate. I did not get you that you are talking about air mouse. Sorry. I do not have air mouse.
                              • Diah
                                • Feb 2013
                                • 6357
                                just to be sure you did hard reset correct..
                                1-while the set on plug it out from wall socket
                                2- plug out any cable / antena etc from the set ( keep it solo )
                                3- press on the tv side panel volume - & power and keep press then plug it in wall ac again.. the front LED will change to green... after it change to green release the keys you pressed before.
                                4- leave the set it will reset and it will show you first install but it will reset again and reboot..--- this mean after the set rebooted 2 time and the first install remain on screen the set finished reset.
                                you must use air mouse. because its plug & play with android
                                • Dobsuk
                                  • May 2020
                                  • 127
                                  • England
                                  Thank you! I am going to try some of them now....
                                  • Diah
                                    • Feb 2013
                                    • 6357
                                    there is procedure of rollback 2015 set firmware listed at Sony UK ,,you can download the pkg.
                                    • Dobsuk
                                      • May 2020
                                      • 127
                                      • England
                                      Yeah, mate! I did that few times. I can see the green led light and you can see that my TV is coming in the first Welcome screen after hard reset.
                                      • Dobsuk
                                        • May 2020
                                        • 127
                                        • England
                                        Yeah, i found the same but it looks it does not work. And can see the comments under the post, seems nobody has success with that rollback
                                        I tried and using your advice, Diah
                                        It looks i need to looking to buy Main board
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • karthur
                                          Vizio D65x-G4 Volume changes on its own
                                          by karthur
                                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                          06-05-2025, 08:13 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • Ruptor
                                          Sony MHC 6600 volume clicking
                                          by Ruptor
                                          Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                          05-21-2023, 05:32 AM
                                        • jason123
                                          Sony STR-DN1030 Distorted audio when Volume adjusted
                                          by jason123
                                          New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
                                          All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
                                          First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
                                          Second thought was the ribbon cable from front display to control board (V-Flex,...
                                          06-05-2022, 12:54 PM
