LG 47 LM8600 - No Video
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4536
    • Italy - Milan
    #41
    Re: LG 47 LM8600 - No Video
    test C512 , C508 near L505, rectify, L505 maybe is a stepup.
    check akso if the micriswitch pins are connected to eprom (the one with yellow paint spot)
    • anupkg1985
      • Sep 2020
      • 180
      I can read 8.2V on C512 and 11.2V on C508. Also pins 1-4 are connected to GND of that microswitch and 3.2V present on pins 5-8.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4536
        • Italy - Milan
        #43
        That 8 v feels out of place for me, let me think..
          https://www.badcaps.net/forum/attach...0&d=1606335986
          There are 4 more switching power supplies, you can see inductors with220 and 6R8 markings, that you need to check. There should be power supply that produce the AVDD boosted Voltage and also minus power supply for VGL, to bad they do not provide marking for Voltage test points.
          • anupkg1985
            • Sep 2020
            • 180
            Yes I have tested those, could you please find the reading in comment#40. There is a 16.43V on L506 inductor.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4536
              • Italy - Milan
              #46
              for the L505 i see also a slight low imput voltage of 11,2 when it have to be 12v, can you test the input v at the fuse?
              • anupkg1985
                • Sep 2020
                • 180
                I'm not able to locate the fuse on the board, however I checked the voltage on each pin of LVDS and max I could get is 11.46V from main board.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4536
                  • Italy - Milan
                  #48
                  It seems a bit low, maybe you can test the 12v on psu with a dummy load? Or does you feel heat on the tcon chips?
                  • anupkg1985
                    • Sep 2020
                    • 180
                    I'm getting 11.89V on PSU when mainboard connected. There is little heat on t-con chips but I believe it's normal operation.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4536
                      • Italy - Milan
                      #50
                      I guess 12v is ok, have you found the missng Vgate high and Vgate low? 27v/ -6v..
                      • anupkg1985
                        • Sep 2020
                        • 180
                        I could measure 27.7V on C528 and -4.9V on C538 caps, not sure if thats what we are looking for?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4536
                          • Italy - Milan
                          #52
                          Yes, the tcon is defenately outputting the right tensions i guess, so no problem with it, even if i don't know what it means and don't think changes some, connect all things , turn on tv and push the tcon button, let see what happens, if nothing i guess there's a problem on the panel, also try all the previous voltages with panel connected. Have you got an eprom programmer?
                          • anupkg1985
                            • Sep 2020
                            • 180
                            No I don't have eprom programmer bu can arrange it. What is the further test? Do you think it's worth of giving try with new t-con board or more likely panel it self is bad?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4536
                              • Italy - Milan
                              #54
                              • anupkg1985
                                • Sep 2020
                                • 180
                                There is no change in voltages after connecting panel, still no picture or osd menu.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4536
                                  • Italy - Milan
                                  #56
                                  If you can get a CH341A programmer with clip you can easily reprogram the i2c eprom on the tcon, not the flash one near the input, or program it only if the i2c doesn't solve, but it's difficult to find the original dumps. Have you pressed button?
                                  • anupkg1985
                                    • Sep 2020
                                    • 180
                                    Yes, nothing happens by pressing that button on t-con.
                                    • Diah
                                      • Feb 2013
                                      • 6557
                                      cutting off TX signal to panel always never being T-CON firmware issue. its MHz Freq cut off at the Main T-CON IC.. reasons always 1 of 3 this TX the main boards didn't send it because of BGA or the T-CON Main IC fault ( T-con replace ) and the third damage ( open circuit at the panel )
                                      you did test one ribbon disconnected with video signal, and you got only white half mean reason No 3 out. stay 1 of 2 T-CON replace or MB BGA so easy some time the test will be.
                                      • anupkg1985
                                        • Sep 2020
                                        • 180
                                        Not sure but it's very confusing for newbie like me. I'm just concerned about the panel, if it's bad then there is no point to invest money in the t-con. Also I saw many videos of solving this issue by baking the main board in oven, do you think I should attempt that? I'm just concerned of damaging main board.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4536
                                          • Italy - Milan
                                          #60
                                          On some models a problem to the panel,, can cause the tcon software to set a flag in the eprom that switches off the tcon in protection, but in this case , now i note, the tensions are present so no eprom problem. Now have to test if signals come to tcon, on the lvds rails at the eol resistrs 100 ohm, have to see a tension around 1,3v, if the rail that carries the sync signals is missing i think image is not displayed. This is somehow a rare defect i think. The option of mainboard cpu bad soldering is not impossibile, so a test on the lvds lines maybe can reveal cpu to tcon output.
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • maneatingmonkey
                                            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                            by maneatingmonkey
                                            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                            03-27-2024, 07:17 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • mmartell
                                            General Questions on the Relationship Between Mainboard, TCON and Panel
                                            by mmartell
                                            My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                            I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                            And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                            01-06-2024, 01:32 PM
