LG 47 LM8600 - No Video
  • anupkg1985
    • Sep 2020
    • 180
    Re: LG 47 LM8600 - No Video
    Yes all caps are reading 12 ohm except one just below L103 (not sure about the number, could be C336) is not showing 12 ohm. Below are the reading on 8pin ICs -
    Ribbon connected / Ribbon disconnected
    IC302 Vin 0.8M Lx 12 ohm / Vin 0.8M Lx 12 ohm
    IC300 Vin 0.86M Sw 44K / Vin 0.87M Sw 44.5K
    IC303 Vin 0.86M Sw 37K / Vin 0.87M Sw 37.4K
    • anupkg1985
      • Sep 2020
      • 180
      IC302- Vin 0.8M Lx 12 ohm / Vin 0.8M Lx 12 ohm
      IC300- Vin 0.86M Sw 44K / Vin 0.87M Sw 44.5K
      IC303- Vin 0.86M Sw 37K / Vin 0.87M Sw 37.4K
      • Diah
        • Feb 2013
        • 6557
        My Post #15 point C. you are just diving at parts of T-CON had other function.. so first need to know yours panel where and how it work..
        Yours Panel & Its T-con used not only as Normal 3D TV. but its ability of its Hz used also at Close Video Displaying System as Panel Info at airports/Stations/Terminal Gate etc. which the system work on NON LVDS Signal.. but 12C /SP controlled by UART hex command.
        • anupkg1985
          • Sep 2020
          • 180
          Thanks for the clarification on that. As per your post#15 point 1, what voltages do you expect on pin 43 to 48? As I noticed on the main board, pin 42 to 46 are connected to GND, pin 47 is N/C (not connected) and pin 48 to 51 are connected to 11 V.
            As you can see, the 3 buck converters, one has very low Ohms reading on the output pin compared to other output pin of other 2 buck converters.
            If you look at the schematics of the IC302, you need to trace out the LX pin which goes to the inductor, and then you will have filter caps connected to the other ends of inductor, so it can be bad MLCC or the loads that are connected to the output inductor is bad.
            • anupkg1985
              • Sep 2020
              • 180
              I see that pin 7 and 8 are connected to Rx pin of the IC302 which then connects to inductor L302. I could see the caps C131, C329, C332 are connected to other end of inductor, which reads 12 ohm. Also I could see there is one inductor L103 connected in parallel, could that be a reason to show low reading on those caps?
                So right now if you do not have LCD panel connected to the T-CON board, what DC Voltage do you have on the caps that show 12 Ohms readings.
                • Diah
                  • Feb 2013
                  • 6557
                  Not Much as want to know the LVDS signal 12V supply and you have it on 48-51 as you wrote.
                  • anupkg1985
                    • Sep 2020
                    • 180
                    I'm getting 1.03V on those caps, panel disconnected.
                      What is the Vin feeding that IC?
                      • anupkg1985
                        • Sep 2020
                        • 180
                        It's 11.65V on Vin (pin2) on IC302.
                          It may be setup as 1V Buck converter, you can verify if that is true or not by checking the feedback resistor network, see the R1 and R2 of the IC spec sheet and see the resistors value used in your board to set the output Voltage of this Buck converter, see page 6 of the spec sheet.
                          • anupkg1985
                            • Sep 2020
                            • 180
                            Sorry I couldn't locate those resistors on the circuit. Could you help to locate?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4536
                              • Italy - Milan
                              #34
                              my opinion: the measurement on that caps are normal, that is the common dc-dc for the cpu vcore that has an high consumption then low ohm reading, 12ohms never tells about a short, the lg recent displays are different from other ones, the half side connect test never reveal an half good picture but vertical lines , there are many inductors on the tcon board, it must chek the voltage on every group of big mlcc near each inductor and report here, the voltages are common more or less so we can judge if good or not.
                                I would check other Voltage outputs of other buck converters too to get some idea if they are working and putting out correct Voltages or not.
                                • anupkg1985
                                  • Sep 2020
                                  • 180
                                  Below are the Vout on other IC and similar I could measure on the mlcc around those ICs.
                                  IC302 1.03V
                                  IC303 3.3V
                                  IC300 1.8V
                                  Also I could measure voltage on each mlcc on the tcon board. Not sure if tcon is good and issue with main board?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4536
                                    • Italy - Milan
                                    #37
                                    every inductor is for a dc-dc stage, near the inductor some caps of a certain dimension, not the smaller ones, test on those caps. Mark only the tensions you find, not the place. The tensions you marked are surely good.
                                    • anupkg1985
                                      • Sep 2020
                                      • 180
                                      I'm getting 1.7V, 1.03V and 3.2V on the big caps around those inductors.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4536
                                        • Italy - Milan
                                        #39
                                        there are 7 inductors so 7 tensions, L506 is a stepup so in the group of 5 caps you must find a tension over than 12v, L505 is step down so on C512 you have less than 12v, L502 is step down and you find less than 12v, L301 is stepdown so less than 12v in C314, L304-L305-L306 are stepdown so less than 12v. Test also C500, C 505, and since i can't identifily the stage for the Vgate high test every single "big" cap for a tension about 27v, you must also find a -6v approx.
                                        • anupkg1985
                                          • Sep 2020
                                          • 180
                                          i think you measure wrong, there are 7 inductors so 7 tensions, L506 is a stepup so in the group of 5 caps you must find a tension over than 12v, L505 is step down so on C512 you have less than 12v, L502 is step down and you find less than 12v, L301 is stepdown so less than 12v in C314, L304-L305-L306 are stepdown so less than 12v. Test also C500, C 505, and since i can't identifily the stage for the Vgate high test every single "big" cap for a tension about 27v, you must also find a -6v approx.
                                          Here are the readings -
                                          L506 16.43v
                                          L505 8.22V
                                          L502 3.2V
                                          L301 1.53V
                                          L304 1.03V
                                          L305 3.2V
                                          L300 1.79V
                                          C500 1.01V
                                          C505 1.7V
                                          Not sure where to test Vgate voltage?
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • maneatingmonkey
                                            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                            by maneatingmonkey
                                            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                            03-27-2024, 07:17 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • mmartell
                                            General Questions on the Relationship Between Mainboard, TCON and Panel
                                            by mmartell
                                            My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                            I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                            And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                            01-06-2024, 01:32 PM
