SONY 65" 4K - Horizontal Line on top
  • 280zx
    • May 2020
    • 43
    • US
    Looking at picking up a 3D TV SONY 65" 4K - XBR-65X900A for $20 and was wondering if it's worth the trouble. It has horizontal lines on the top 1/3 of the TV. Is it fixable?
  • Diah
    • Feb 2013
    • 6395
    Re: SONY 65" 4K - Horizontal Line on top
    90% the issue at T-CON replacement fix it
    10% damage at the edge side of the panel
    Taiwanese AUO Panel + T-CON are good unless there external force to issue damage at them.
    20$ i will pay you 100 if you brought it to me lol
    • 280zx
      • May 2020
      • 43
      • US
      Thanks I was thinking it could be the T-Con board, but was worried that it could be a bad panel.
      • 280zx
        • May 2020
        • 43
        • US
        I bought the TV and here is what it actually looks like. Could this be the T-con board? HELP
        • Diah
          • Feb 2013
          • 6395
          1-you need to call the menu setting and see how it look..
          2-remove the panel bezel to see if there damage on panel... this is different from first post.
          • 280zx
            • May 2020
            • 43
            • US
            Here is a picture from the setting menu. It has those pink and blue strips down the middle. I hate to have to through it in the trash. Would like to fix it versus stripping it for parts sale. Any idea what it could be? Panel looks good.
            • Diah
              • Feb 2013
              • 6395
              do the test of one ribbon disconnected at one time.. and call the menu setting... let see how its look.
              EDIT: before you start with the test i mentioned above.. you need to take out all ribbon cable out and the LVDS too. inspect them under good magnifier from end to end, you may find damage at the pins contact.
              • 280zx
                • May 2020
                • 43
                • US
                Here pictures of the screen with the T-CON cables disconnected. I start from left to right disconnecting 1 of all 4 connections. Last picture is all reconnected.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4362
                  • Italy - Milan
                  Sorry the damage is 100% panel, unfortunately you have a combination of vertical and horizontal issues so this means bad source and gate drivers, for the vertical bars maybe there a corrosion on board for liquid spill, but i'm not sure since this has not to do with horizontal problem that seems of electrical surge, but if the liquid spilled also at the bevels maybe has ruined the gate drivers, i think 99% is unfixable, but 20$ is so low price, sell the boards..
                  • Diah
                    • Feb 2013
                    • 6395
                    the location of color line has being changed.. very early to judge on panel issue..
                    you didn't write about inspection the ribbon cable and lvds.. please show me yours T-CON and the lvds sockets on it as well the lvds socket on the Main boards.
                    • 280zx
                      • May 2020
                      • 43
                      • US
                      The vertical bars have moved to the left. I cleaned all the 4 connections on the T-CON board before putting them back in.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4362
                        • Italy - Milan
                        [QUOTE] vertical bars have moved to the left. [QUOTE]
                        Hey! this is a very good new, maybe the liquid is still liquid and does produces momentary defects not destructive, time to dismantle the screen bezel before the corrosion takes place...
                        • Diah
                          • Feb 2013
                          • 6395
                          okay--
                          i wrote inspect the ribbon cable contact pins under good magnifier if one damage or short or moved to aside..
                          if they are all fine--- disconnect the LVDS the small one and turn on ( call menu always at any test ).. let see what will show to you
                          • Diah
                            • Feb 2013
                            • 6395
                            could you please calm down and dont distributed the trouble shooting.... this is TV not swimming pool.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4362
                              • Italy - Milan
                              why you have preference than me? i write my suggestions , nothing to do with you, you has not the exclusive..
                              • 280zx
                                • May 2020
                                • 43
                                • US
                                I removed the following cable which I marked off in red. Tried to power on TV and had no picture just clicking sounds.
                                • Diah
                                  • Feb 2013
                                  • 6395
                                  so it went to protection after disconnect the small LVDS. so T-CON SOS feed back working.. you need to invest first with T-CON if you were sure 100% there no visual damage at the panel.
                                  • 280zx
                                    • May 2020
                                    • 43
                                    • US
                                    I have ordered a T-CON board today since it was only $25. Thanks for your help and I will post once I get and swap the T-CON board. Hopefully it fixes the issue. Once again thanks for your help.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4362
                                      • Italy - Milan
                                      25 $ for an huge complex board is very cheap, but as a general rule defects that covers only part of the screen are never related to tcon.
                                      • 280zx
                                        • May 2020
                                        • 43
                                        • US
                                        Diah I replaced the T-Con board and in the process it looks like the t-con ribbon cables are damaged. Can't seem to be able to find new cables. I think the previous owner must of damaged them.
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
                                        • bbrain
                                          Sony KD-55AG9 TCON?
                                          by bbrain
                                          I have this problem with my Sony 55' AG9.
                                          It flashes 4x.
                                          I have found the service manual, and seems it is the TCON.
                                          Before I buy a TCON can someone check the vid?
                                          Thanks in advance!...
                                          09-19-2024, 10:50 AM
