SONY 65" 4K - Horizontal Line on top
  • pazoline
    • Dec 2020
    • 26
    • Brasil
    #61
    Re: SONY 65" 4K - Horizontal Line on top
    Originally posted by Davi.p
    I have found a video where horiz. sparse lines, but intermittent, can be solved via signals masking..
    This is what we are trying tô do my friend!
    • 280zx
      • May 2020
      • 43
      • US
      #62
      pazoline did you post that video on youtube yet?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4362
        • Italy - Milan
        #63
        i know.. was a plus info
        • pazoline
          • Dec 2020
          • 26
          • Brasil
          #64
          https://youtu.be/ohYETE9CAYs
          • pazoline
            • Dec 2020
            • 26
            • Brasil
            #65
            Originally posted by pazoline
            Hi Friend , do you still have your old t con board?
            • 280zx
              • May 2020
              • 43
              • US
              #66
              I watch the video, but not sure which ribbon contact to tape off. As for the t-con board I still have the old one.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4362
                • Italy - Milan
                #67
                Which is the problem? I saw back that you found the correct pins to block..
                • pazoline
                  • Dec 2020
                  • 26
                  • Brasil
                  #68
                  is the 4th pin, on each cable
                  right side, 4th pin right to left, on both conectors
                  Left side 4th pin left to righ on both conectors , but you will need to test wich side to block testing one at the time
                  • pazoline
                    • Dec 2020
                    • 26
                    • Brasil
                    #69
                    how do i call an admin on this forum?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4362
                      • Italy - Milan
                      #70
                      search for Topcat...
                      i have not seen your video.. so you have solved.. but 280zx not... aren't the same situations?
                      • pazoline
                        • Dec 2020
                        • 26
                        • Brasil
                        #71
                        clock signals 1 to 4
                        • 280zx
                          • May 2020
                          • 43
                          • US
                          #72
                          So if I understand correctly each ribbon has its own clock signal?
                          • pazoline
                            • Dec 2020
                            • 26
                            • Brasil
                            #73
                            yes , each side each conector, always in the 4th pin
                            • pazoline
                              • Dec 2020
                              • 26
                              • Brasil
                              #74
                              • 280zx
                                • May 2020
                                • 43
                                • US
                                #75
                                pazoline did you get a chance to change the bad t-con board yet? I have not had a chance to get the ribbon cables installed yet. To many projects going on.
                                • pazoline
                                  • Dec 2020
                                  • 26
                                  • Brasil
                                  #76
                                  Hello My friend! , i am still waiting for the t con board , do you have any news where the board is? maybe a track code?
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • Ihandyrepair
                                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                    by Ihandyrepair
                                    Hi guys
                                    I just started fixing 4k TV few months ago. so I am still learning a lot
                                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                    then it started to show the ghosting white image.
                                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                    it has 3 thin small boards at the bottom of the...
                                    12-05-2022, 04:18 PM
                                  • cubytus
                                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                    by cubytus
                                    Hi to all,
                                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                    01-10-2024, 01:26 AM
                                  • thelankanguy
                                    Sony KD-55X9000F TCON Issue
                                    by thelankanguy
                                    The TV shows a black screen with no image.
                                    TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                    Later both ribbons were disconnected and TCON voltages were tested.
                                    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                    There is also a short to ground in this circled inductor.
                                    Is this a TCON issue or something else ?...
                                    12-13-2024, 12:27 AM
                                  • bbrain
                                    Sony KD-55AG9 TCON?
                                    by bbrain
                                    I have this problem with my Sony 55' AG9.
                                    It flashes 4x.
                                    I have found the service manual, and seems it is the TCON.
                                    Before I buy a TCON can someone check the vid?
                                    Thanks in advance!...
                                    09-19-2024, 10:50 AM
