Samsung LN46A530 image issue when power on
  • Darouss
    • Nov 2020
    • 3
    I have a Samsung LN46A530 TV with an issue at power on. At first, the TV was powering on/off and clicking. I change 3 bad caps on the PSU and the issue was fix.
    But, at power on a part of the screen is very dark and change progressively to be OK after 3 to 10 sec. I checked the connection at the t-con board and all seem to be ok.
    Is someone have any idea of the source of the problem?
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung LN46A530 image issue when power on
    Maybe backlight?
    • Darouss
      • Nov 2020
      • 3
      I don't think the problem come from the backlight.
      With a video it will be easier
      https://www.dropbox.com/s/jcxfcvpb52...35.12.mp4?dl=0
      Thank you
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Panel is bad on that side, the side tabs voltage need to be isolated with tape cut-off method or they need to be removed if possible.
        https://www.badcaps.net/forum/showthread.php?t=87395 This is a TV I had and the symptom is very similar.
        • Cooperr
          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
          by Cooperr
          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
          10-21-2025, 01:11 PM
        • Cookybaby
          Samsung UN60ES6500FXZA Power Supply Issue
          by Cookybaby
          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
          Make: Samsung
          Model: UN60ES6500FXZA
          Power Supply P/N: BN44-00525A
          Symptoms: The TV was...
          08-20-2023, 12:26 PM
        • Drewwol11
          Samsung QN49Q70RAFXZA Power Cycling Issue
          by Drewwol11
          My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
          I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
          08-31-2021, 09:32 AM
        • lp20th
          Samsung Plasma TV Power Supply Issue
          by lp20th
          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
          11-28-2023, 10:28 AM
        • mrtek
          Samsung UN43NU6950FXZA No power
          by mrtek
          Hi
          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
          Main fuse = OK
          Back light LED = OK. Power them with aux power source
          LED output = OK 156V
          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
          07-20-2025, 08:06 PM
