JVC LT-48C570 Suspect firmware
  • 6BW6
    • Jan 2015
    • 55
    JVC LT-48C570
    One blink and the led goes out after about three seconds, all power lines up and running otherwise no sound and no screen.
    LED backlights OK on external tester. I suspect firmware corruption..... can anyone help? Screen number is LSC480HN08.8
    Thanks, Dave
  • nomoresonys
    • 12331
    • U.S.
    Re: JVC LT-48C570 Suspect firmware
    Maybe start with testing the voltages at the connector on the powerboard with the cables all hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts. Also good clear straight on pictures of each board and one of the whole back so we can see how they are connected, can upload by hitting go advance and manage attachments.
    • 6BW6
      • Jan 2015
      • 55
      Thank you for the reply.
      We are looking at CON201 on the power board-:
      1) On bk = 0
      2) 5V = 5V
      3) on/off = 130mV
      4) 5V sb = 5.09V
      5) 5V = 4.74V
      6) 5V = 5.09V
      7) Gnd
      8) Gnd
      9) Gnd
      10) 12V = 12.09V
      11 12V = 12.09V
      Oooops I've missed pin 1 the BL adjustment pin (this is zero)
      On the main board The LVDS voltage is being generated this seems to go into the CPU then appears to come out and find it's way to the Tcon board fuse - there is 0V from here (maybe it isn't being switched).
      I scoped them all and seemed 'ripple & hash free'.
      Dave
      • nomoresonys
        • 12331
        • U.S.
        Looks like the mainboard isn't sending the bl-on or the on/off signal, 130 mv is way too low.
        • 6BW6
          • Jan 2015
          • 55
          Yep 130mV ain't going to do much.... funny thing is if you leave it in this ON state I noted the LED flashed once after a minute or so producing a click in the speakers. Whether it's CPU or firmware I'm not to sure.
          I can't detect any voltage variations when I first switch it On, it may well be in a self protect mode, I've not studied the CPU yet..... be interested applying 1.5V to see what happens.
          Dave
          • Diah
            • Feb 2013
            • 6614
            Originally posted by 6BW6
            JVC LT-48C570
            Thanks, Dave
            i dont trust this tester... because even you have shorted one LED the rest will lit on... as you do the test while screen in place so you just make judgment with visual lit .
            start script at any TV when turn on it send Power ON... and BL on at same time.. in about view ms time. so before you play with main boards.. set your voltmeter as 200-250 V DC and put the probe on any group of led socket + - and turn on you will find that you have voltage read as high then low... tell us what you got and post photo f the led socket.
              Dave
              Are you talking about backlights LED flash on for seconds?
              Keep meter probe on chassis and monitor BL-ADJ (PIN 1), and ON/OFF pin each time you turn on the TV to see how high the Voltage jumps up to before settling down.
              There should be 3 control signal, you show only two signals: BL-ADJ, ON/OFF. There should also be PS-ON.
              Show us good clear pictures of the whole backside of the TV so we can see how all the boards are connected together, also good clear straight shots of the power supply board and around the connectors so we can see the pin names of the connectors.
              • 6BW6
                • Jan 2015
                • 55
                Re-: LED backlights, no not even a flash.
                1) They work ok on an external tester
                2) They work ok when 'ON bk' pin externally powered.
                There is NO evidence of one or more LED/s backlight failure, it is clearly NOT a backlight issue.
                Therefore I can only suspect either CPU or Firmware corruption AND to add to the fun the firmware is stored in the CPU since there is no EEPROM chip on board.
                Just had word from JVC UK - it ain't one of their telly's....! These are made specially for Curry's & PC World, by Vestel no doubt, I fired a Email off to them as JVC UK suggested, I await their response but no help will be their reply.
                Dave
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  A photo of your mainboard and/or sticker from the back of the TV would confirm but looking at the power supply on ebay it doesn't look to be made by Vestel.
                  • 6BW6
                    • Jan 2015
                    • 55
                    Mainboard T.MS3546S.711.... sorry I don't think it's a Vestel as I said, more like a Chinese Shenzhen MTC product a good possibility.
                    Dave
                      Right now we do not even have the pictures of the boards to show us what we are dealing with.
                      • 6BW6
                        • Jan 2015
                        • 55
                        Sorry thought the board number would suffice, here we are-:
                        https://ibb.co/LhPh6yP
                        Dave
                          C:\Users\David & Lilian\Documents\IMG1
                          There are so many numbers we need to know about the board.
                          There is blank PCB part number.
                          There is PCB revision number.
                          There is PCBA part number.
                          There is PCBA revision part number.
                          And we can also see the condition of YOUR BOARDS and how solder joints and some condition of the components of your board if we can see the pictures of the board. So basically we need to see YOUR board.
                          • 6BW6
                            • Jan 2015
                            • 55
                              That is only picture of the main board.
                              We need the pictures of the whole backside of the TV showing all the boards and how they are connected together, and also good clear straight shots of the whole board of each board so we can clearly read the prints and pin labels of the connectors.
                              Why don't you use attachment function (Use GO ADVANCE) to attach your pictures instead of using third party website.
                              It hard to do long distant troubleshooting when we do not have the TV in front of us to look at.
                              BTW, you do have proper tools to do repair, correct?
                              • 6BW6
                                • Jan 2015
                                • 55
                                https://ibb.co/xGpkHVT I'll try a better one....!
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  You can not upload pictures here? Just click go advanced then manage attachments.
                                    you can not upload pictures here? Just click go advanced then manage attachments.
                                    +1
                                      We need good clear straight shots of the boards, we also need the straight shots pictures of the bottom side of the power supply board so we can easily see the pin labels, parts designators, prints, traces, etc.
                                      • zklgfs
                                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                        by zklgfs
                                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                        08-11-2025, 02:14 PM
                                      • TheUser
                                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                        by TheUser
                                        Hello to everyone ,
                                        This is my first post here, and i would like to share with you a small story in case you can help me.
                                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                        02-10-2024, 02:07 PM
                                      • gurj1979
                                        Ubiquiti firmware help. US-8-150W POE
                                        by gurj1979
                                        Hi guys.
                                        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                        Got New chip and writes good.
                                        THE PROBLEM...
                                        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                        Does anyone have a Good Firmware I can have?...
                                        07-22-2024, 05:13 PM
                                      • Slapito
                                        Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                                        by Slapito
                                        I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                                        Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                                        I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                                        I already downloaded the BIOS update file from msi official...
                                        10-09-2025, 02:00 AM
                                        Acer Spin SP313-51N-509V Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                        This specification for the Acer Spin SP313-51N-509V Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP313-51N-509V boardview and SP313-51N-509V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 11:20 PM
