TCL 43U6406 firmware problem
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, i got this TV that show only logo at startup. I try putting new firmware but when i hold down power btn at statup to get flash proces, TV reboot itself and wont start flash proces. I use USB 4GB with FAT system file format. I downloaded original firmware from official TCL website. One time TV started the flash proces but it stuck at one point at stay there for hours. After that no luck with it. Is it possible that the chip went bad or there is other thing to consider?
    Board label: 40-MT58DU-MAB4HG
    Manifactuer of TV: TCL (also known as THOMSON 43UC6406)
    ...the quieter you become the more you are able to hear...
  • nomoresonys
    • 12088
    • U.S.
    Re: TCL 43U6406 firmware problem
    This may work, notice how he blows on it but just short bursts because obviously long breaths would just heat it up and you don't want that, you can also give it a shot of freeze spray and see if it stays on longer, to try and verify the issue: https://www.youtube.com/watch?v=bJ8HSLlOwA8
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      I do not this that this is the problem here. When i put Update.zip on USB and hold pwr buttin when turning on then it say 'No update available' and stay there. If i put the 'V8-T658T01-LF1V551.zip' on stick it blink LED in stick and restart itself.
      • hopkok
        • Oct 2014
        • 171
        • Slovakia
        Hi, did you solve it? Need firmware too.
        • AlexVG
          • Apr 2022
          • 134
          • SPAIN
          Do you know keys places?
          I have dump, and I can fix it. (dump is not the same that firmware)
          However, TV loose Netflix access without keys transfer.
          (Also you need to have a programmer for EMMC. It's not available with USB)
          • 2informaticos
            • Nov 2020
            • 5
            • Spain
            Hi AlexVG,
            I have a friend in Madrid with a Thomson 43UD6406 which gets stuck in logo.
            He said has found many bads on EMMC.
            Can you help with working dump?
            Thanks,
            Vali.
            • AlexVG
              • Apr 2022
              • 134
              • SPAIN
              Originally posted by 2informaticos
              Hi AlexVG,
              Thanks,
              Vali.
              PM
              • helpmepleasethanks
                Thinkpad T440P bios repair after WIFI whitelist mod
                by helpmepleasethanks
                As per the the rules, here are the specifications of my laptop :
                • Make and model number : Thinkpad T440P
                • Serial number (S/N) : PB-03A7V7
                • Model type - Model (MTM) : 20AW-S2N800
                • Bios version : 2.50 (not 100% sure, that's what I remember)
                Here is the problem, and the events leading to it :
                1. Upgrade screen, keyboard, trackpad, RAM and CPU
                2. Reboot and use the laptop for a bit : everything is working fine
                3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
                4. Boot up the device : bios warning, as expected
                5. Shutdown the device again (no power)
                6. Connect the 8-pin clip of a CH341a
                01-09-2025, 12:09 PM
              • toti24
                (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                by toti24
                dell precision m4600 laptop
                i7 2760qm
                8gb ram 750gb HDD
                intel hd 3000 integraded and nvidia quadro 2000m
                pleasea bear with me english isnt my language and ill try to be as clear as possible
                note i live in mexico in a very small town..
                thank you.
                laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                the brick happened when i was installing win 10 using usb.
                used rufus and officia microsoft.iso
                it finished copying files from usb...
                03-06-2022, 08:39 PM
              • ekozeko333
                by ekozeko333
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
              • nordlicht
                ThinkPad X1 Nano (20UN) bricked
                by nordlicht
                Hi guys,
                while trying to mod my ThinkPad X1 Nano (model 20UN) I got too impatient to hold the wires pressed to the SPI Flash contacts, so I soldered wires to it, but wasn't paying attention when connecting my programmer and, stupidly, swapped VCC and GND. Thus I fried the main SPI Flash, and I only have an incomplete/corrupt dump (u49_incomplete.bin). The secondary SPI flash on the board (W25Q256JVEIQ) seems to hold two redundant copies of the EC firmware (at 0x1000 and 0xc0000) as well as a redundant BIOS copy. I am fairly confident that the secondary Flash dump is correct (dumped...
                04-27-2022, 12:46 PM
              • corrize
                Nikon D800 camera - flash don’t work and capacitor don’t charge
                by corrize
                Hello, I'm stuck in troubleshooting…
                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                10-01-2022, 10:02 AM
