LG75SK8000PTA Blue screen no image shadows showing
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    Re: LG75SK8000PTA Blue screen no image shadows showing
    Tcon 1 original board has a damaged fcc ribbon cable socket at the bottom of the tcon board so i cant connect it to the cff lower boards
    can i still power up this and get the SP1 flash and dump it on a usb stick trnsfer it to the new tcon sp1
    • Diah
      • Feb 2013
      • 6602
      1- When some one here describe his profile as professional.. our answer to him and suggestion will be on level of trouble shooting and testing different from any other who are new as technician.
      Back to the highlight i remarked on your post.
      A- Damage socket on Original T-CON will tell why you have just for 1 minute screen after you heated the original T-CON.
      any damage to ribbon socket will cause 90% damage to the ribbon cable silver pins. & possibility damage to the panel it self if there are swiped pins ( the first 4 pins or more ) which transfer VCC to the panel.
      B- there are no need to power ON or using the original T-CON on the set.. put yours ORG. T-con on your work table and solder the SPI Chips out, and replace it on the new T-CON. of course you can make dump of it before you put it on the new boards.
      mores i cant explain.
        • 12331
        • U.S.
        Video there on procedure, chip has quite a few pins, so if you are not up to snuff on soldering technique, better practice on some junk boards, also plenty of soldering how tos on youtube: https://www.youtube.com/watch?v=jg4_nn3nBzs
          Hi Guys ,
          Just following up on a LG tv with a very frustrating issue
          Can you please Help
          Please refer to Below link
          https://www.badcaps.net/forum/showthread.php?t=89518
          cheers
          11-05-2020, 05:01 AM
        • dicky96
          HP Elitebook Screen blank - backlights but no image
          by dicky96
          Hi guys
          I'm trying to fix this laptop screen
          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
          OK so I have the original screen which works but has lines across the bottom quarter of the screen
          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
          04-28-2021, 07:30 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • jean luc ferre
          acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
          by jean luc ferre
          on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
          i tried the hard reset, cmos reset, changing the ram without results.
          in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
          The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
          but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
          Yesterday, 03:54 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
