LG75SK8000PTA Blue screen no image shadows showing
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    Hi Guys ,
    Just following up on a LG tv with a very frustrating issue
    Can you please Help
    Please refer to Below link
    https://www.badcaps.net/forum/showthread.php?t=89518
    cheers
  • nomoresonys
    • 12274
    • U.S.
    Re: LG75SK8000PTA Blue screen no image shadows showing
    No need to make another post about same tv, just give your original thread a bump and it will move up.
      by wazzadj@hotmail.com
      Hi Folks ,
      I have a 75 inch Led Lg tv
      Model LG75SK8000PTA
      that has a strange problem
      i have no sound no picture ,
      i can turn it on and the backlights come on and I get a very dull Blue screen
      when I use the remote I can see a response like its trying to show a picture on screen but cant get a image just very dark shadows moving around the screen
      I have checked all the smps voltages are all ok and present
      I have replaced the Tcon board with a new one from LG
      I have checked and cleaned and reseated SVDC cables
      I have 12v...
      10-14-2020, 06:54 AM
    • dicky96
      HP Elitebook Screen blank - backlights but no image
      by dicky96
      Hi guys
      I'm trying to fix this laptop screen
      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
      OK so I have the original screen which works but has lines across the bottom quarter of the screen
      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
      04-28-2021, 07:30 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
