Weird Screen Failure Samsung UN55KU6300F
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Just posting this out of curiosity of who else has seen similar failures on this or other similar models. I picked this up yesterday and was told by the owner that they were watching the TV one evening. Zero issues. Next morning it looked like the attached. The spot is almost a perfect circle and there is no visible impact damage. She said that it was not hit with anything and there were no kids in the house. I personally haven't seen a failure quite like this.
  • JDC
    • May 2015
    • 273
    Re: Weird Screen Failure Samsung UN55KU6300F
    I've seen this before but I can't tell you why/how it happened, sorry.
    • chrismurphy
      • May 2014
      • 251
      • australia
      looks like a cap from the led backlight has stuck to the diffusers
      I cant see how it could be a screen fault
      • R_J
        • 9628
        The fault is with the lcd panel itself, there are video's showing a way to remove this by using a q-tip and working the black circle to the edge of the panel. Here is one video : https://www.youtube.com/watch?v=X_sn6yU5tao
        There are other video's, just search "black circle on lcd panel"
        I have not tried this myself as I don't have not had a panel with this problem
        • Diah
          • Feb 2013
          • 6613
          interesting this black circle.. but why at the video and OP photo happened only at top end of the panel ??? we saw some dirt or insect spots before... i would take out the panel and take close look from behind first before . start with this massage
          • aaronwt6
            • Apr 2013
            • 855
            • US
            I worked at it for a while and was able to get some of the pixels to clear up but no where near the success the person in the video was having. It did at least prove to me that the spot was not a crack. The change in pressure caused the spot to shift as I was working on it. Very strange indeed.
            • R_J
              • 9628
              It may take some time to get rid of the spot, Not much of an option other than replacing the lcd.
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • KYBOSH
                Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                by KYBOSH
                Picked this up to resurrect.
                When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                Sometimes the TV would produce an expanding blob on the screen before going black.
                See Video here
                I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                Did I get another defective board or is there an issue with...
                09-16-2024, 07:48 PM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
              • JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                by JunkmanJimbo
                Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                Please help. Thanks in advance!
                08-12-2025, 11:45 AM
              • Kiberge
                Samsung LH82QENELGC/EN Help needed - Static line on screen
                by Kiberge
                HI guys!
                I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                04-22-2024, 11:28 AM
