Thomson 55UA7706 LCD TV startup problem?
  • SMPS
    • Aug 2020
    • 18
    • Eesti
    Re: Thomson 55UA7706 LCD TV startup problem?
    Originally posted by budm
    1) The pictures of the boards are very poor, I cannot read the pin label (the oin names are printed on the bottom side of the board) of the connector of the power supply board that goes to the LED driver board.
    Yes, below is new, do they help?
    2) Were you getting 24V to the LED driver board? And now you don't since you start playing with FSFR1700XSL and D404?
    This 24V comes to inverter board from psu pin no. 10 (marked red). And yes, I have 22.92V before but after disconnect/reconnect this 14pin cable, I dont have this anymore, also, no standby.
    3) The 24VDC is generated by FSFR1700XSL so the circuit was working. I do not understand why you start messing with the FSFR1700XSL.
    Because (also question 4) ) one technician suggested to measure C401 22uF/50V voltage and there is 1.6V, they told that I must check this part of circuit, I then measure this SMD components and find this zener conducted both ways, soldered it off and checked with a zener tester - same result, 0.0009V zener voltage.
    4) As you can see that D404 is connected in parallel with resistor. So when you check D404 off the board, does it show conduction and low resistance (<10 Ohms) in both directions.
    See previous.
    5) Right now you need to get the FSFR1700XSL working again before going back to troubleshooting the backlights issue, or just buy a new power supply board assembly that match the number on the barcode sticker, not the blank PCB part number..
    I dont know this zener real name value - if I order new FSFR1700XSL and if there is this broken zener...i dont think that this new IC helps, they also fail probably.
    6) Where is the pin that is supposed to have 56V?
    In inverter board, pin 11 to 14 is marked 56V, in PSU, pins 12 to 14 is marked as 60/120V, 11 is not connected (see 1. (PSU connector) and 4./5. picture (inverter connector).
    Pictures 2 and 3 is LED stripe connectors from inverter board.
    Last 2 pictures is PSU FSFR1700XSL circuit top and bottom view
    • Diah
      • Feb 2013
      • 6395
      before we got lost.... lets follow yours POST
      this is your first POST.
      Originally posted by SMPS
      Inverter board can get from the main power supply as follow voltages:
      +24V (I have there +22.66V)
      +56V (I have 0 (zero)V)
      after i asked you to disconnect 24V socket and plug in again.. you wrote at POST No 8
      Results are:
      P_DIM +0.430V
      Fuse F1 from T-CON, +11,988V (both sides)
      Measured at inverter board IN DC MODE:
      +56V pins: measured +41.45mV it is not very stable also - here seems something wrong ????????????
      +24V pin: measured +22.92V (little low but not very?)
      PT pin: measured +0.55mV
      BL_ON: measured +3.109V (little low?)
      P_DIM: measured +0.4316V
      3D_EN: measured +0.62mV
      so the inverter turned on and the 56V exist but low 41.45V.
      it mean you have LED back light issue or Inverter issue. that's all before you went to play at HOT AREA... BTW i think your measurement to the zener Diode wrong... you need with Ohm testing that read resistance at one direction only.
      • SMPS
        • Aug 2020
        • 18
        • Eesti
        Look next answer
        Yes, I wrote this but there is +41.45mV , not 41.45V. There is over 1000x lower value this +56V rail.
        Then is only possible that inverter itself is bad, this OZ9998, all other semiconductors is good. And If you need I can take picture this zener measurements - virtually https://i.ytimg.com/vi/GwRyAGgpbPg/maxresdefault.jpg but I have 1000ohm resistor and adjustable supply, if I now get new THT zeners from manufacturer packaging I get good results - for example, same setting, 3.6V zener I get very close (to name value) results (if you need how close - how many I measure?), If I get 15V zener then I get also very close results, also 12V and this other zeners which located near FSFR1700XSL give me result 18.028V for example. This broken one gives me 0.0009V reading and 0 ohm (multimeter reading) but if this really helps, I can measure until to 0.001ohm resolution but - do this help?
        continuity test/diode test gives me also short "peep" signal, both sides.
        What DMM I using now? Fluke 110 and UNI-T UT139E, there is virtually no difference, only second show me 1 count more.
        Once again, this very low +56 rail...this is only tens of millivolts - and this sends me from the beginning.
        Today morning I re-measured again new LED strips and sure that new ones is good, all LEDs lit.
        87.7V is one group voltage (18 LEDs).
        If this helps also I can post picture my DIY tester (circuit is here: https://www.drive2.ru/c/513423827611419614/ ) but if this LED lit then there is no errors. Old LED stripes which located at this moment inside a panel, they are definitely broken because they lit very weakly.
        E: maybe my writing skill barrier is really high but I mean milli-Volts at there 41.45milli-Volts, not Volts
        • Diah
          • Feb 2013
          • 6395
          aha... mV was easy to write 0.41 any way ..so now you have of sure zener defect and back light strings defect. i would say start first by replacing the BL and when you got the correct zener will be easy to you for further trouble shooting in case there were more issue
          • SMPS
            • Aug 2020
            • 18
            • Eesti
            OK.
            I once thought that I marked with a dot, not a comma... My country also have a comma for this kind of separation, but I get previously resented that I used a comma and tried to prevent now
            Anyway I need to figure this zener value out now and new inverter or ICs. I drew a diagram but i will only get the component measuring device tomorrow or the day after tomorrow, so if i get it done maybe it will give some overview to find out the value of the suitable zener. OK, lets see
              Your post #21:
              "This 24V comes to inverter board from psu pin no. 10 (marked red). And yes, I have 22.92V before but after disconnect/reconnect this 14pin cable, I dont have this anymore, also, no standby."
              Are you now saying you do not even has standby Voltage?
              • SMPS
                • Aug 2020
                • 18
                • Eesti
                #27
                I finally got new PSU chip and now is still only one problem - this damaged zener.
                Like as I say some time ago, I was measured all components which located near this FSFR1700XSL chip and clear is that this D404 (some kind of zener) is damaged BUT - how can I be sure what value zener this must be?
                I draw this part of PSU zircuit and measured all little SMD parts, this circuit is below and there is also componets values which I measured.
                Now - how I can calculate this D404 value? Or rather what does this value depend on, on which should I proceed? There is no this kind of zener circuitry in FSFR1700XSL datasheet.
                If I choose an incorrect zener - I am afraid thst this ends badly to new FSFR1700 chip?
                Therefore - how I can choose correct value zener?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  The data sheet for the IC says VAR (Autostart Reset Pin Input Voltage) = MAX VLcc
                  VLcc on the data sheet says maximum 25V
                  So it's possible that the zener may be somewhere around that value.
                  https://cdn.badcaps-static.com/pdfs/...04400a7892.pdf
                  • Diah
                    • Feb 2013
                    • 6395
                    well till now i never faced Glass Ziner defect. buy any value glass ziner and compare the test with diode mode. LOL
                    • SMPS
                      • Aug 2020
                      • 18
                      • Eesti
                      #30
                      Yes, this is weird but - I was measured this maybe tens of times and compared to others and this is clear that this zener is defective. I dont know why? Also, first time I have this fault but lets see when new IC is in place and also new zener.
                      I have now 17V, 18V and 24V SMD zeners too. I think that maybe I`ll try then 18V here?
                      • SMPS
                        • Aug 2020
                        • 18
                        • Eesti
                        #31
                        topic locked
                        Zener has a 18V value. If this zener breaks, then also FSFR1700 fails and need to be replaced, no empti place here! Although it may seem to work even without this zener it not work without a zener.
                        Now this TV works again.
                          Thanks for the follow-up.
                          • caseyjay_48
                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                            by caseyjay_48
                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                            09-23-2022, 08:08 PM
                            by momaka
                            03-15-2023, 10:17 PM
                          • x_orange90_x
                            by x_orange90_x
                            01-29-2025, 09:24 PM
                            Thomson NEO 15 WWN15I5-8BK1T Notebook Specification for Upgrade or Repair
                            This specification for the Thomson NEO 15 WWN15I5-8BK1T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWN15I5-8BK1T boardview and WWN15I5-8BK1T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-07-2024, 06:21 AM
                            Thomson NEO X14C WWX14C4BL64-P Notebook Specification for Upgrade or Repair
                            This specification for the Thomson NEO X14C WWX14C4BL64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4BL64-P boardview and WWX14C4BL64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
